Master or slave cylinder how do I know
  • Master or slave cylinder how do I know
    OK so after just 3 to 4 years looks like my clutch slave cylinder has given up again but maybe is the master how do I know for sure before buying a new one and any links to part numbers would be amazing I've tried looking but I get easily confused
    The master cylinder is located at brake pedal area. So have a look to see if there's any fluid escaping?
    1995 Audi S2 Avant
      Good point thanks for the tip will check tomo in daylight
        if you clamp the rubber hose on the gear box (with hose clamp)and press clutch pedal if its building pressure(get hard)the master is in good shape.
          Cheers I'll try that too before spending
            Master cylinder defo I've got fluid on the clutch pedalanyone got links or part number
              Pete at Quattro corner has them for £85 ish. I phoned him last week when I thought I needed one. Luckily, he was out of the office and not able to take my order. In the meantime, I re bled the clutch using the reverse bleed method and it sorted the issue nicely. My clutch pedal wasn't returning properly and the bite point was very low. I did look at Autodoc (no recommendation from me) and they have got a seal kit if you fancy refurbing your existing one. From my experience with them, they will probably send you the wrong kit
                Cheers bud I've had lots of stuff from Pete over the years not cheap but always sends the right parts, on another topic bit strange I was trawling through ebay found this and thought of you. I was just about to put the link on your post so I'll leave it here
                https://www.ebay.co.uk/itm/Nothelle-...uWa:rk:40:pf:0
                  Nice! If I put it in my window I wont be able to see out
                  Let me know if you need to borrow my reverse bleed kit
                    It goes on yer garage wall
                      Really? I thought it was a German sun visor
                        Cheers for the offer I have a spanner monkey to do my dirty work
                          Lucky you. I am the monkey in the garage here
                            I do what I can but usually make things worse
                            • #15
                              OK peeps Pete only has the 3B type with the thinner rod can I take my rod of and fit it to this one or is there any other types that work
