As titled any tips and advice gonna have a crack at it after work as spanner man is out of action for 6 weeks
Tips on fitting clutch master cylinder
Fit a hose clamp on the hose from the reservoir to the MC to reduce fluid loss. I used an old rag to catch the contents of the hose inside the car. removing the clevis is simple enough and then there is only 2 allen key headed bolts to remove. Don't cross thread them when you refitMike
http://www.s2-audi.co.uk
- 1 like
You need either some long allen keys or allen sockets on 1/4" extensions to get to the bolts easily -there are cut outs in the pedal box casting to allow you to get to them
I just used the plastic bag over the reservoir and refit cap method to stop the fluid spill, works fine.
Take the drivers seat out and use cushions
