Speak to CG Motorsport they will reline your old disc and reface your pressure plate and fit a new diaphragm spring.
7A clutch
Originally posted by steve briance View PostOn 30/03/18 I ordered sachs part number 3082.912.001 from autodoc. It was £120 and is working in the car now ever since. It was actually listed for a 3b if I remember rightly and, amazingly someone from autodoc actually phoned me up to confirm what I'd ordered was what I wanted!
Note the 'Type MF240', this is what is stamped into my cover, so yes, this is the right cover for sure. Just need the friction plate, which I think is the trickier one to get hold of.
Took a while to getting around to responding properly to this, just connected some dots, hence the post now.
Ahh yes. It says it is but, is it definitely just the pressure plate? Thats the part number I ordered and have on my car, I just don't remember buying (or have receipts for) a friction disc separately!
If you got that and CG motorsports to recline your existing disc that would be you back on the road with a new oe spec clutch.
Think about a reface of the flywheel while its easy to get to... Your pics look like it's in better shape than mine was but you can't beat a nice flat flywheel to help stop judder and increase life of the friction disc.
For £97, I can only assume that it is just the cover, but you are right, that with a rebuilt friction disc and job done.
Thing is thought, CG will reline the plate for £35, and rebuild the cover for £45, and can essentially be done on a next day service(!)
Here's the links just so you know I am not lying!
https://clutch-specialists.co.uk/pro...ate-upto-240mm
https://clutch-specialists.co.uk/pro...-cover-rebuild
Cover info above may be useful for others in future.Last edited by Bowie69; 25 November 2020, 20:52.
Check out 1862 809 001 as the sachs friction disc for the 7a coupe quattro.
It seems to be available in some places mainly Germany but, you could maybe cross reference that number with other brands you trust.
I got to that as the alternative to the high performance sachs friction disc autodoc do list for the cq20v for big money.
Originally posted by Error404 View PostSpeak to CG Motorsport they will reline your old disc and reface your pressure plate and fit a new diaphragm spring.Nothelle S2 Avant
- 1 like
Well. They seem to have made a mistake and sent me back a brand new clutch!
Before
And after
And I double checked, a few little marks confirmed it is my clutch!
Highly recommended. Took just over a week, door to door and cost just over £100 including postage both ways.
Sent from my iPhone using TapatalkNothelle S2 Avant
- 2 likes
