ABY to SMF part number
  • bobby singh
    • Jul 2021
    • 78
    Hi everyone - I tried to search this before posting but could not find a clear answer.
    Background
    I'm building a spare high power engine and want to get the bottom end all balanced etc
    My car currently has a 3b smf with a 707 clutch which off course I can not use in the new engine as I want to balance the lot and keep my car on the road.
    I need help to id a 3b smf
    Looking on ebay I found https://www.ebay.co.uk/itm/224945504...YAAOSw1bNiXS0L
    This flywheel has a part number of 034105271C and according to the description is the same for 3b & 7a - is that true?
    Forum search bought up 3b part number as 034 105 270AA or 034 105 271J
    Thanks in advance
    Bobby
  • rxl
    • 1913
    that is a 7a one. buy aftermarket one.
    • bobby singh
      • Jul 2021
      • 78
      Thanks for reply - does 7a one also work on aby?
      Aftermarket - I have considered that but they are x 3 the price and not sure if the advantage is justified
      • rxl
        • 1913
        would work but has its issues
        • bobby singh
          • Jul 2021
          • 78
          Can you expand on the issues?
          • _ShurikeN
            • Mar 2010
            • 733
            • Country: Russian Federation
            I've heard rumors that 7A flywheel pin position is a few grads shifted from one on 3B/ABY flywheel. Did not check myself.
            It can be essential on stock motronic, not an issue with aftermarket engine management.
            • pfi
              • Jun 2016
              • 274
              • Country: Norway
              Compared my 7A with my 3B, can't see any pin difference but 7A is ~1kg heavier.
              You also may use any other 5-pot flywheel but then it needs to be machined and of course have inserted the trigger-pin at proper position
              Another alternative may be 3B aftermarket ALU flywheel
              • rxl
                • 1913
                its not what i would put on upgraded engine. your downgrading it. trigger issues are possible, weight, mashining costs that are the downside of it.
                • pfi
                  • Jun 2016
                  • 274
                  • Country: Norway
                  what is what You wouldn't put on upgraded engine ?
                  • rxl
                    • 1913
                    your ebay link. just my opinion.
                    • pfi
                      • Jun 2016
                      • 274
                      • Country: Norway
                      The eBay looks like a 7A, reasonable priced.
                      What You want to put on depends on what You want to achieve ...
                      My FW's :
                      - NF : 10.5 kg (milled)
                      - 3B : 10.7 kg
                      - 7A : 11.5 kg
                      - 3B Alu : 5.1 kg
                      - AAN SM Alu : 5.5 kg
                      personally I'd liked ~8kg, mby try to machine more of my NF to see if it's possible ...
                      my 7A :
                      the part# can't be trusted, it's probably a "raw" number of the FW before machining to specific engine, think there's a thread regarding this on the forum some place ...
                      • bobby singh
                        • Jul 2021
                        • 78
                        wow thanks for the information guys yes the engine will have a EFR 83 so maybe best to stick with a light weight item.
                        Its only a weekend toy but having light flywheel could help in getting those rev's up
                        • pfi
                          • Jun 2016
                          • 274
                          • Country: Norway
                          If "fast" rev's up is Your goal, go for aftermarket Alu FW ...
                          • bobby singh
                            • Jul 2021
                            • 78
                            Well I want easy rev'ing haha
                            I'm using a diesel crank to make 2.5l so anything to help
                            • pfi
                              • Jun 2016
                              • 274
                              • Country: Norway
                              2.5 crank in 2.2/2.3 block or in 2.5 block ?
                              IMHO a stroker is more for torque than fast rev's ...
