Hey... BTW - anyone know what the difference between the Coupe housing and the Avant/Sedan housing is? I mean, the rearmost part, P/N 017 520 53N and 017 520 53E - they look the same but are they? Or rather - will the snout off a Avant bolt on to the rear part of a coupe? Juuuuuust curious...
Quaife for the 01E transmission?
017 520 053N OR E HAVE TO BE WRONG NR'S..... it shuld be 017 525 053N or E .... maybe the lower boltholes in front of casing are som slicly different... the rest will fit right in....Comment
Originally posted by caterpillar017 520 053N OR E HAVE TO BE WRONG NR'S..... it shuld be 017 525 053N or E .... maybe the lower boltholes in front of casing are som slicly different... the rest will fit right in....
Ouch... Now you guys can't have much confidence in me right now, huh? Geez, and I already apologized once. I mean how hard can it be... F-word, f-word, f-word... Yes, it should be 525 and not 520 as I said.Comment
It looks like a standard open diff.Originally posted by Greg_S
There was somebody racing in Rally witha an Audi S2 but don't have any recalls of an Audi 80 Rally car.
What do you guys think?94' RS2 Coupe TT (Twin Torsen
)Comment
Question and answer from him:Originally posted by Greg_S
"Is there any part number you can read on the diff?"
It is a works diff bought from David Sutton Part number stamped on it is 262H101 and these other numbers also appear 525055 also 088409131 and WWO2 on different parts
)Comment
THAT's people looked like a WF diff or nearly not likeli a ADV diff....Originally posted by The SpanishQuestion and answer from him:
fill fit in all audi 80/90/s2.... BUT THE DIFF HAVE THE 4,875 -1
...... DOES ANY HAVE SUTCH TRANNY
the QUATRO cars MUST HAVE THE SAME gearing in front AND REAR
Found this site in California.
I already have e-mail them for the diff setup of the S2
http://www.tatomotorsports.com/rallycars.asp (just scroll down)
Cheers94' RS2 Coupe TT (Twin Torsen
)Comment
Got and answer from TMS (see previous post)
Hi Rafael:
We used QUIAFE LSD front and rear, and stock on the center. On the old 5 speed we did not need to modify anything.
On the 6 speed we had to make slight modification to the front and rear to make it fit properly. It worked excellent, like a whole different car.
You can contact us at 661-299-5224 or send us your tel. number and we can explain more.
-george plsek
Comments please
EDITED: Can any of the US guys call to get info on this?
Telephone costs, hour difference and different language makes it hard for me to get a good answer here of what is need it to modify.
I suspect we need Quaife P/N used by them and what modifications.
Still I don't understand what is different on the rear between the 5 speed and 6 speed?
If somebody is going to call please let me know. Otherwise I will try my best to find out more about this.Last edited by The Spanish; 24 February 2005, 09:21.94' RS2 Coupe TT (Twin Torsen
)Comment
New answer from TMS
Rafael:
No problem. The difference onthe 6 speed is the front diff, the casing is not large enough for the bearings, so some parts have to be machined.
-george94' RS2 Coupe TT (Twin Torsen
)Comment
buying new parts form quife is no problem, finding a front torsen, just like the back one from v8, that would be awesome news. It would be much cheper than quife ATB.AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.netComment
V-8 Torsen vs Quaif
I too spoke to the folks at TMS. I spoke with Georges father. He said that the Quaif would "lock faster" than the v-8 torsen diff. To install the Quaif in the rear diff he said to remove the diff locking mechanism (from the coupe style rear diff) & again some minor machining & a "bushing" to fit the diff case.Originally posted by Albertbuying new parts form quife is no problem, finding a front torsen, just like the back one from v8, that would be awesome news. It would be much cheper than quife ATB.
Another small piece of the puzzle.
Chris
Almost forgot.
He also said that Quaif told him that they did not make a Quaif for the newer style 5-speed & 6-speed but that he knew that the gearbox differental for the 4000, 5000 (USA) models were similar to the later style gearbox differentals.
Last edited by A1QSHIP; 24 February 2005, 20:09."Nulla tenaci invia est via"Comment
Albert did you receive the V8 torsen yet?Originally posted by Albertbuying new parts form quife is no problem, finding a front torsen, just like the back one from v8, that would be awesome news. It would be much cheper than quife ATB.
)Comment
next weekOriginally posted by The SpanishAlbert did you receive the V8 torsen yet?
