Spec Clutches, Slipping No Warranty
  • fasterthenrs2
    • Nov 2007
    • 275
    • Home: Latvia Current: United States
    SPEC CLUTCHES SLIPPING NO WARRANTY, posting this because 2 SPEC clutches filed in less than 4K, not cowered by MF, plus Josh was very rood and unhelpful. Trying sell me another clutch saying this one should work. Im alset with them, I tried two stage3 and stage 3 plus they both filed under SPEC provided specs. Stage 3 failed at 330 WTQ, 3 Plus 463WTQ.
    Is any one else experience this ????
    My friend Alex Wentworth( Couple of his cars has bean in a eurotuner) stopped using SPEC because they product was failing and they didn’t stand behind.
    DD 1990 CQT 800+HP SOLD
    1/4 mile 10.70@135.66
    (SOLD)
    http://www.youtube.com/watch?v=Yy-YlssmSfY
    http://www.youtube.com/watch?v=8XgzVJyvrfg
    2003 A6 4.2 Quattro
    97 MB S320 DD
  • quattro
    • Dec 2004
    • 768
    Iv got a stage 3 rated to 400bhp or 450bhp i think and only running 300bhp, the uptake is very jurkey/vibration and it has sliped once in the dry with a hard change from 2nd to 3rd, but apart from that no major broblems.
    2,500k in miles!
    Probably the longet S2 project in history EVER!
    • kwlw
      • Sep 2004
      • 1025
      • Country: Lithuania
      Are you sure, that your flywheel wear allows you to use ceramic clutch? From what I've discovered, that if pressure is too low on ceramic/sinter, then it will slip and glue to pressure plate or flywheel. At least local "wizards" say this, and offer flywheel/pressure plate "matching service" what is actually machining (and balancing) flywheel "outer ring" according to the clutch needs.
      Sau
      • zlobo
        • 967
        i use a ceramic disk from cluch net with a sachs pressure plate and i got no problems.
        And i my frend is usin a spec ceramic cluch and his vluch is slipping but he have 690hp.
        difrrence between the sachs pressureplate and the spec plate is that its nit hard like the sachs when you press the cluch.
        ABT C5 Lord Of The Rings
        2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
        2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
        2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
        kostic.nu
          I ran a Spec stage 3 in my car for a while, no slipping that I noticed but it was very jerky and made horrible screeching noises, It would seem to be ok then suddenly grab so I'd be stalling the car in traffic. I replaced it with a Stage 3+ which so far has been great, still bites hard but more progressive and no nasty noises or juddering (actually it will sometimes judder if you try to pull away really slowly at low rpm)
          My mate has a Clutchnet paddle in his RS4 and IMHO its almost undriveable. It felt like "My first driving lesson" when I drove it the other day. Very embarrassing
          I have a Sachs competion clutch in the ur and its brilliant, a little heavier on the pedal but otherwise you'd never know..
          • jogi730
            • 2335
            I am also using the Sachs race spec organic clutch. So far no issues, but will see how it holds up to the new set-up. The pedal is 'a little hard' as John says, but I have got used to it now.
            Chris
            Audi 90 quattro (Typ 85)
            20v turbo conversion
            • fasterthenrs2
              • Nov 2007
              • 275
              pics of 3+
              pics of 3+
              (SOLD)
              2003 A6 4.2 Quattro
              97 MB S320 DD
              • fasterthenrs2
                • Nov 2007
                • 275
                more pics of 3+
                pics of 3+
                (SOLD)
                2003 A6 4.2 Quattro
                97 MB S320 DD
                • terrybullwon
                  • Mar 2006
                  • 8782
                  Hope this is not the case, i have been told the 3+ will be ok with my GT35R.. we will see
                  And if not it will be for sale.
                  Chef
                  • fasterthenrs2
                    • Nov 2007
                    • 275
                    with GT35 you should reach that with no problems
                    It was freewheeling with467WTQ, with GT35 you should reach that with no problems.
                    (SOLD)
                    2003 A6 4.2 Quattro
                    97 MB S320 DD
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      What does 467WTQ convert to the flywheel?
                      Chef
                      • fasterthenrs2
                        • Nov 2007
                        • 275
                        around 584FTQ
                        If I did the math right 584FTQ
                        (SOLD)
                        2003 A6 4.2 Quattro
                        97 MB S320 DD
                          mulitpy by 1.25 to convert
                          • Faheemo
                            • Feb 2005
                            • 544
                            • Country: South Africa
                            My 3 plus spec clutch didnt last much longer as well, for the record 034 did refund me for it - when i bought a spec 5 but then ther was the issue of the whole clutch kit being incorrect/not suitable which i did NOT get any compensation for.
                            S2 Coupe fully built.
                            10.9 1/4mile 0-100 in 3.5secs
                            Precision 6262 turbo
                            The Green Monster
                            • lynx
                              • Jan 2005
                              • 125
                              034 rs4 clutch kit, what supposed to hold 500hp. Only chipped rs4, slipped from day one. Spec said it is overheated! Yeah right, it didn' t hold power from day one, even after 2000km correct break in!
                              I had also in my s2 stage 3, witch failed (slipped) after gt30r install and 2bar of boost.
