Right, just having a few thoughts about this after it's been on for a while.
Did anyone fit a spacer in the prop shaft when they did this to make up the difference in length or did you do like me and just let the CV joints take up the slack? I think a 10mm spacer might be a good plan.
I still have a pretty annoying vibration at 1500rpm so I'm going to try and either shift the engine back a little on the mounts or modify the transmission mount as it's a bit tight.
Car feels much better with the 3B item in there, wish I'd had some material taken off and had the friction surface skimmed as the clutch judders a little.
