A little help with 3B gearbox/diff oil change and part no.
  • Jonas_R
    • 3781
    • Country: Denmark
    Ok
    Is there any how to or BTDT on the forum about changing gearbox / diff oil on the 3B?
    I read somewhere that the ABY should be filled 7mm to the top.
    Also what is the part no, for the gearbox drain plug and filler plug and filler plug, drain plug for the rear diff?
    Jonas
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • Jonas_R
    • 3781
    • Country: Denmark
    Anybody?
    • Mr.Crossfire
      • 145
      It's quite straightforward. First remove the filler caps, so you don't end up with drained box with stuck fillercaps. The caps have 17mm socket head. Then remove drain plugs, drain the box, plugs back in and fill. I don't see any harm in filling the box until the oil starts to come out from the filler hole, that's how I've done it. Used Castrol TAF-X in the box, and SAF-X in the rear diff.
      • zlobo
        • 967
        in my new old gear box i used i used redline Light Weight ShockProof in the gearbox and in the diff Heavy Weight ShockProof
        in the old gear box i used same oil as Mr.crossfire.
        ABT C5 Lord Of The Rings
        2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
        2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
        2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
        kostic.nu
        • Jonas_R
          • 3781
          • Country: Denmark
          Thanks.
          I'm planning to use Castrol oil.
