Diff Lock Question
  • Kliminati456
    • Mar 2010
    • 215
    Diff Lock Question
    Can the one control unit in my 200 control both center and rear diff lock actuators?(016 swapped in)
    The previous owner of my 200 20vtqa swapped in the driveline from a 5000tq(016), so center and rear locking abilities. The 200 stock only came with the rear locking ability. So my question is can I use the stock control unit to run 2 actuators instead of just one? and if so what would it take, is it as simple as T-ing off 2 vacuum lines from the ones that come from/ go to the control unit?
    Also can some one confirm that it is the white/blue wire that needs to be cut to override to 15mph speed cut out? (assuming the 200 works like the B3s do)
    Justin
    1990 Audi Coupe Quattro= http://www.s2forum.com/forum/showthread.php?t=46309
    1991 Audi 200 20VTQA= http://www.s2forum.com/forum/showthread.php?t=54410
    1987 Audi Coupe GT
    If you don't get an answer here, I suggest you post your question here:
    You will have to register (not much info needed) to get an account.
    • Tonks4x4
      • Nov 2005
      • 3062
      Yes that would work fine. Just a T piece from the controller to the 016.
      Or you could wire in an extra diff lock controller under the dash and pipe it separately. The diff lock control is operated by a momentary switch. Not an on off.
      Audi Nut!!!
