Gearbox crunching into gear
  • mike74
    • Apr 2014
    • 615
    After a serious dose of paranoia setting in after me filling the box with millers GL4/5 stuff I changed it out for some Castrol Syntrans GL4 fluid instead. There was an instant improvement over the gear change. Maybe worth a try if you're still having issues with it
    • bertman
      • Apr 2007
      • 1173
      • Current: United Kingdom
      #47
      Bringing this thread back into play.This is really doing my noggin in.
      Symptoms are getting worse.Today I changed the clutch Mc as it was weeping a little,made F A difference.Whatever is happening is getting a lot worse.It just feels like the gears are reluctant to engage in any gear,very stiff and baulks sometimes, then it works fine then it doesn't. Today I had a complete inability to get any gear what so ever,even when repeatedly dipping the clutch,wiggling the gear lever,it only got a gear when the car slowed.One minute the clutch feels quite light,then other times its heavy.
      Please keep throwing suggestions at me
      Rob
      Ragussa green avant RS2+ spec
      Racing blue Octavia VRS mk2 estate-Remapped now to 250 bhp
      Audi coupe gt-slow as hell but loads of character-sold
      • Jack4688
        • May 2010
        • 1004
        Hate to say this, but it sounds worse than my box was and I ended up having to replace it
        As it's gear selection issues you have, it sounds like the g/box internals are in need of repair/replacement. Whether it's the synchros, selector forks or whatever else reconditioning a box isn't likely to be the most economical way to sort it.
