Right then just been for aa drive and somit is rubbing somewhere I think. The tyres show sign of it on the back but are sitting way to low in the arch to touch under normal driving but may just be touching over the old sleeping policeman.
The other noise I am getting sounds like rubbing but and there is a big but I have good clearance all round except only 3-5mm on the steering arm ball joints, is that alright. I cannot see any signs of rubbing on one but the other has a slight rub mark.
The noise also gets louder turning left and dissapears turning right. That sound like a bearing to you. I have good clearance on the spring housing a good 10mm and the only other rubbing posibility is the inner arches all round but the car is sitting too high for that to happen. Got to be a bearing hasn't it???
May have to nip the car down to jason for him to suss the banging out and also the bearing.
Guys where can I get bolt sleeves from. The bolts for the Hub carriers I bought are to big to go through the strut leg holes so I need to bolster them up up drill the strut leg. Which would be the sensible option??
Getting closer everyday.
Aaron
Aaron
