S2 understeer
  • A1QSHIP
    • Aug 2004
    • 975
    Who is AudiWidgets?
    :QUOTE=s2dude]What is audiwidget?
    I cant find any site called this when I google it??!!!
    Please explain...... [/QUOTE]
    Search this site www.tdif.com for AudiWidgets post.
    "Nulla tenaci invia est via"
    • maRS2
      • Oct 2003
      • 366
      • Home: France Current: Thailand
      #32
      S2dude:
      I think Correy from quatrotonic sell them or you can get them directly from audiwidget in the US check on here:
      http://www.tdif.com/phpBB2/viewtopic.php?t=436
      http://www.tdif.com/phpBB2/viewtopic.php?t=423
      Sephiroth401:
      My setting are only for people doing hard cornering 70% of the time if you are mostly driving straight motorway then you will wear really quickly the inside front wheel.
      RS2 chip by mihnea,PKM short IM, forge dump valve, 3" custom stainless exhaust, 18"X8" Porsche 996 rims, conti contact 245/35 Front 225/40 Rear, QR sport top mount, Powerflex bushes, aloy sub frame bushes, neuspeed 19mm RARB,Hard tranny mount, V8 torsen on RS2
      • Sephiroth401
        • Mar 2006
        • 255
        • Home: United Kingdom Current: Devon
        #33
        Originally posted by maRS2
        S2dude:
        Sephiroth401:
        I'd second that' motorway driving rags my tyres.
        Devon is nothing but corner after corner so your settings would be good down here, although my car is standard.... poo
        AudiManDan
        • robins
          • Dec 2006
          • 48
          • Home: United Kingdom Current: Azerbaijan
          #34
          It's mostly A and B roads that I drive on, with plenty of bends and roundabouts so I am not worried about straight line speed or tyre wear. I need acceloration and cornering. I also need to be able to ride a few bumps and I think the mods you suggest will effect that too much. That's one reason why I decided to stick with the S2 rather than a get a Skyline. The GTR was very quick, but so hard to aim over the bumps, it also tramlined!!! Its a track car, not an every road car like my Audi.
          I want to get some other work done as well, and don't have the time, space or experience to do it all myself so I need to put her into somewhere like quattronics anyway. Can anyone recommend a good specialist around the Norwich area?
          • geryS2
            • May 2006
            • 815
            • Home: Belgium Current: Portugal
            #35
            hi all,
            following on this old thread regarding understeer,
            i fitted the original Avus 17 x 7.5 ET 45 at the rear with 225 45 tyres
            and Avus wheels 17 x 8 ET 32 ( from an S3 i think) at the front with 245 40 tyres
            any chance u think that could improve the handling, or is it a bad idea to put wheels with two different offset on the same car ?
            cheers
            S2 's and oldtimers
            • caterpillar
              • 2480
              #36
              understeer
              [QUOTE=newsh;201092]Only if you know how to drive[/QUOTE
              in norway when its snowing; it might turn into rain, the you hav 10-20 cm with slutdge in the road.... and the car goes straight forward .. i took the car in again with some handbrake handling...had i have thicker bar rear, the prob havent turned in...it will told me, you are goin too fast in the sludge...
              • Mcstiff
                • Oct 2004
                • 504
                Just wanted to comment that 1'= a arc min or 1/60th of a degree and 1"= an arc second or 1/3600ths of a degree. I know you guys were thinking feet and inches in the beginning but just thought it was worth mentioning. Also a degree ° can be written with alt+130 if you have a keypad.
                1995 1PissedOff90sigpic1991 USDM CQ 7aT
                • jade
                  • Jan 2005
                  • 1811
                  #38
                  Originally posted by geryS2
                  hi all,
                  cheers
                  I run that set up at the present on my RS, I have found it now under-steers much less may a little over-steer
                  RS 2 580HP
                  • geryS2
                    • May 2006
                    • 815
                    #39
                    perfect then !
                    there were larger wheels at the front for the sport Quattro and again for the RS3,
                    with the little offset of the 8x 17 ET32 Avus wheels, the front track must be larger by 1.5 to 2 cm...than previously
                    i ll comment on the feeling later after some miles...
                    S2 's and oldtimers
                      • 12431
                      If I remember right the MTM S2 Coupe used wider wheels on the front to the rear to minimise understeer aswell
                      • rynaqui
                        • Mar 2012
                        • 2752
                        • Country: Malta
                        #41
                        265 fronts, 235 rears
                        1996 S2 ABY Silver
                        • Henkjan
                          • 1705
                          • geryS2
                            • May 2006
                            • 815
                            #43
                            yep, everyting's perfectly explained in this paper, just got to do some more work on the coupe to get it up to the MTM standard !
                            S2 's and oldtimers
                            • rynaqui
                              • Mar 2012
                              • 2752
                              • Country: Malta
                              #44
                              How is it possible to get that wide up front on a coupe?
                              1996 S2 ABY Silver
                              • quattrostyle
                                • Oct 2006
                                • 6229
                                Wider bumper and wings
