i run 1' toe in on the front, bit sketchy in a straight line at high speed but turns in well, tends to over stear rather than understear,
this is an A4 quattro by the way but intend to try this on my coupe when its finnished
Would you use the same toe in on an S2? I found the A4 Q had less understeer. Will see what new rims and wider rubber does first and will try 1/2" if I still can't turn it in. Will post the results when I do.
i hated my understeer so i got some 18" rs4's, whiteline rear arb (hardest setting), rs2 front arb, solid subframe mounts and some adjustable koni's. now it drifts all day controlable ones tho
Thanks Ski
I'm not going to try that on my current one, as its still 100% standard with low miles, but I'm on the lookout for another one I can take out when I want some serious fun and will put your mods to the test. (Once I make some space on the driveway)
Changing the anti roll bars was pretty much the first thing I did to my car they work brilliantly with stock wheels, springs and shocks. Its the most effective handling upgrade ever, its out of sight and you can easily put the standard bars back on if you want to. I would say there is no down side and the car is much more pleasant and fun to drive.
id have to agree the rear anti roll bar was one of the first mods I did. and its something all s2's need in my opinion. it evens out the balance, and, should u wish, you can adjust it for oversteer.
with the anti roll bar is just seemed to want to turn into the corners a lot more, something audi should of put on there from start if u ask me.
-245/35/18 front wheel 225/40/18 rear wheel
-Neespeed 19mm rear ARB adjustable set on medium.
-P.U bushes all around
-Alloy subframe bushes
-QRSport top mount ( would not sugest those would instead sugest the one from Audiwidget.)
-Billestein
- -1.35° Camber 1mm toe in front -0,45° camber 0mm toe back
And rear torsen to get the power to the tarmac coming out
RS2 chip by mihnea,PKM short IM, forge dump valve, 3" custom stainless exhaust, 18"X8" Porsche 996 rims, conti contact 245/35 Front 225/40 Rear, QR sport top mount, Powerflex bushes, aloy sub frame bushes, neuspeed 19mm RARB,Hard tranny mount, V8 torsen on RS2
audi said; its for safety all the car will understeer
i cant understand this, its mutch better the car are slightly oversteer....then you have more control around the corners.....right
Don't want to go staight in the wall in one of those mountain 180° turn because I came in too fast. The litle tail slide will help to make it. Like on a Mitsu EVO.
Anyway Audi did not make rallycar since year's. they are more into the sleeping father style driving now a day's on their production.
-Billestein
What is audiwidget?
I cant find any site called this when I google it??!!!
Please explain......
i thought the natureral postition of the front was toe-in alittle.
I don't know all I know is that the tyres come out bald and on the threads on the inside, while they look all new from the outside. an from ether offside or near.... hmm isn't that normally due to chamber angle?
