My home made slicks are no longer road legal apparently :mischeif:
Currently using Pirelli P-Zero Rossos which seemed quite good but i'd like to hear what you all recommend. Was it Toyos that were the other favourite? Anybody tried both?
Cheers,
Mark.
91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald Express
I use toyo, T1-S were awesome, newer T1-Rs are good too but not so keen on the tread pattern. Mate swears by the new goodyear f1 so might try those next, good grip and look pretty good too! Never tried the pirellis my pockets are never deep enough!
Ragusa Coupe gone!
totally unimpressed with the pilot 2s on mine, stuck them at the rear the grip is much less than either the goodyears I had or the Toyo's (T1-s).
I was amazed in a wet carpark the front end completey broke away with the pilots on the front at 2/3d's full lock. Went home astonished and switched the toyos at the back to the front and paid another £0.90p to go and try again....toyos gripped. The pilots are on the back and will probably source some more toyos when i get the car back on the road and fleebay them.
Started with p rossos , very expensive, noisey, now on goodyear gsd3 f1 , @100 per corner, great in the wet and comfortable, if money no object and if i was doing the mileage , continental would be prefered.
nb i have been advised that xl spec [extra load] is advised on 4wd motors
Eagle F1s are now very cheap and I have used them for nearly 3 years on the S2 with great results Will be going with them again on some new 17s I have.
Until recently, I've always used F1s, but I've found that they wear very quickly. I'm testing Rosso's on the front now, which seem to be wearing better, but I haven't pushed them in the wet yet - something that the F1s get a thumbs up for.
I thought the Pirellies were very good in the wet, Then again the only thing i can compare to was the cheap Chinese Wanli tyres that came on the car, dangerous in the wet!
Weird thing about the Rossos is there not directional, they have an inner and outer side which i had never seen before. They also wore out evenly instead of scrubbing the outside edge off, but then again i only got a year out of them
@S2_Dave: Did you notice any difference in steering feel? I had GoodYears on my last car and found them a little soft and squidgy. Though i like the look of the F1's, nice big blocks of rubber at the edges.
Cheers, Mark.
P-Zeroes have a rep as being a bit shocking in the wet - Toyos are great in the wet but IMHO Goodyear GSD-3s are better
Look guys these threads are always subjective with little hard infomation apart from 'my mate says' 'I had these on my ...'
But this quote 'p-zero shocking in wet ' takes the biscuit. What c*bblers. Which p zero for starters original directionale rosso nero ? Source of info ? See what I mean
Most modern tyres from the 'known names' are acceptable. Extra load 94Y rating is a defo on the avant and I would use on coupe. Ensure you keep an eye on pressures with ageing alloys. Finally if you run high pressures to save wear then they will not grip well !!!
Right I am off to lie down again
my apologies - was in a bit of a hurry when I posted eariler allow me to be a bit more specific... P-zero neros on a Mk I impreza, me driving. I found them to be _very_ poor in the wet, to the point where (and here I back up my orignal comment) I was shocked at the low levels of grip they provided for a "performance" tire. They had felt good in the dry and tread depth was good. I'm comparing that to experience driving other Mk I imprezas in various conditions on both Goodyear F1 GSD-3s and Toyo Proxes T1Rs
your mileage may vary!
Haynes Manual:As described in Chapter 7...
Translation:That'll teach you not to read through before you start, now you are looking at scarey photos of the inside of a gearbox.
