S8 alloys
  • GazzaG60
    • 4133
    a little. when i first looked into this there are many different versions of whats needed. i couldn't understand this but as the balljoint moves in and out its a little vague that way.
    at weekend i tested the s4 rims on my saloon expecting the rear to need 10mm or so. due to angles off the floor it needed 5mm. when on the floor again its well clear of inside. thats 235 tyre flat arch so you got more room to play with. mine has ball joints pushed in at moment. if i tweaked them out then it would need none.
    for reference the 235 is a 45 too so a bit bigger again. it spins freely.
    • Tango23
      • Jun 2010
      • 427
      • Home: United Kingdom Current: South Africa
      #32
      Many thanks Gazza...I will start the process and see what I end up with!
      • a25c
        • 259
        Have the wheels and 15mm spacers but I don't know what length my extended wheel bolts should be of my URS6...?
        96 UrS6
        96 UrS6 Avant
        Previous:
        '87 coupe quattro, '85 90 quattro
        '95 S2 Avant '89, 200 quattro 1b
        '00 Allroad 2.7T, '02 S6 V8 Avant
        '96 A6 2.5 TDI quattro Avant.
