V70a Kumho's were very good when i had them on the coupe for track days (road legal)...seemed to wear well too and felt fantastic when on temperature. Not sure on current pricing but I think were mid priced and you could choose compound.
Federal 595RS-R
Imola B6 S4 AvantComment
FYI the new Federal 595RS-R is wider then other similar sizessigpicComment
I'm gonna be after some summer track/road tyres for my RS2, I don't have a great deal of experience with different tyres, my last purchase was some Dunlop Sportmaxx RT's for my BMW which seemed to grip pretty well. Anyway if these Federal 595 RS-R's are well rated then I've found a place called mytyres.co.uk that has 225/45 R17 91W's for ÂŁ69.70, think I might get some.Last edited by cardcrash; 23 February 2015, 23:25.RS2 - Project Mental Wheels
RS2 - LHD on the road again
RS2 - reduced to component parts
RS2 Saloon replica
A4 1.8T
BMW 320d Touring M Sport Business Edition auto
sigpicComment
Cool so effectively ET35 on a 8J
I am ET32 on an 8.5J so the wheel centreline will be only 3mm further outboard than yours. These 235/40 should fit OK.. however....
What are you comparing against there? Surely those tyres are not marketed as the same size?!
If it was me i'd be going 225/40 with stock arches... it caused me no-end of pain last time but people have generally said my rim's tighter than most
Given the Federals are wider anyway a 225 is probably more like most 235.
That said i'll be going for something larger in the near future
S2Forum.com AdministratorComment
They are wide for a 245. I ground enough off the rear arm to make a 3mm clearance. Never had it touch. Not even with 150 mph tyre growth.
My wheels are 8.5 et 52.
Fronts have 3mm spacer to clear the far end of the stut arm. I am going to modify this soon as I get a tiny rub when heavy with passengers and working the suspension hard. Spacer out and it won't touch.
Rob..
87 UR 20v ABY
97 S6 Avant
1967 Ford Mustang,Eleanor,460ci v8Comment
Your arches are rolled a bit though Rob?
I think I might get some 235s and measure them against my 245s before I fit them, can always change them if they are new & unfitted. Don't really want to mess about much more with my arch lip if i can help it as the arch liner won't fit properly.
The issue with the 225/40 is only an 88Y.Panthero Coupé quattro 20vt
Let me know what you decide to go for Alex.
I've a mate in the trade-may be able get you some discount.Comment
Not rolled at the front. Rears have had tweek.Your arches are rolled a bit though Rob?
235 in federal?Rob..
87 UR 20v ABY
97 S6 Avant
235 40 is not too tall? I'd expect more issues due to the diameter than the width.Rob..
87 UR 20v ABY
97 S6 Avant
