Maybe that's why Andy had issues with clearance with his? I know I wouldn't want to go any wider than what I have currently with the 245/35. I did try a 255/35 and it rubbed the arch with hard cornering
Any chance of a couple pics of the front of yours Rob?
Anyone know the difference in hub offset between the S2 and RS2 hubs?
I have 235/45/17 Khumos on 17x8 et 35 with 3mm shims to clear the steering arm, NSF rubbed the arch under heavy cornering until I moved the wing out a bit.
Cool so effectively ET35 on a 8J
I am ET32 on an 8.5J so the wheel centreline will be only 3mm further outboard than yours. These 235/40 should fit OK.. however....
What are you comparing against there? Surely those tyres are not marketed as the same size?!
Can anyone tell me why these two tyres are both called Federal 595 RS-R's yet have entirely different tread patterns. I know one specifically says it's a track tyre but still, exactly the same name/different tread, what's going on??:
RS2 - Project Mental Wheels
RS2 - LHD on the road again
RS2 - reduced to component parts
RS2 Saloon replica
A4 1.8T
BMW 320d Touring M Sport Business Edition auto
Hmm, didn't see that on the advert, just says RS-R.
And I've already bought some RS-R's in 225/45, would 235/40's even fit on the standard 7J RS2 wheel??
I've also just bought a set of Toyo R888's for my Super RS2 in 225/45
*edit: Oh wait, I see it in the picture now on the sidewall...
RS2 Saloon replica
A4 1.8T
Well, I cant for the life of me find any wheels with the right off-set and correct centre bore for my RS2's...
RS2 Saloon replica
A4 1.8T
