Audi K jetronic injector 0 437 502 043 Alternative
  • alexandrusima
    • Jun 2017
    • 13
    • Country: Romania
    Hello i was in the process of restoring my daily driver, an 100 2.3 NG with the K Jetronic system.
    While taking care of the fuel system, i've found that 5 out of 5 injectors are dead, code 0 437 502 043, i would like to know if the alternative MB injectors found on the e190, code 0437502047, can be used.. from the first sight i can notice the thread is different... But at the same time i found someone saying these were a good alternative, having similar flow and soo on ....
    Has anyone gone this route ?
  • pfi
    • Jun 2016
    • 274
    • Country: Norway
    Dunno anything about K-Jet, but, if thread's different, forget it ...
    According to ETKA the NG should have injectors w/part# 035133551F
      I guess they're just blocked with gum from bad fuel /ethanol. Have you tried soaking them in fuel system cleaner?
      • pfi
        • Jun 2016
        • 274
        • Country: Norway
        Good suggestion.
        Doubtful that they have all failed at the same time, left unused for a long time?
        • Monkeymagic
          • Mar 2012
          • 3419
          Search the Bosch number, how have you confirmed all 5 have failed, what have you done to test them.?
          • alexandrusima
            • Jun 2017
            • 13
            • Country: Romania
            The car had a CNG conversion from the previous owner, while in process of removing everything, cleaning it, replacing whats needed... I've decided to send the clogged injectors, all 5..., to be cleaned, they returned from the shop and they are pissing everywhere now... so need replacing.
