Central locking stopped working so petrol flap won’t open
  • 4WDrifter
    • Nov 2012
    • 1251
    Today the central locking has failed. Is there a quick way to open the petrol flap?
    1996 S2 ABY Coupe silver
    2003 S3 8L dolphin grey
    2014 RS4 B8 prism silver
  • struikie
    • May 2019
    • 314
    Normally all cars have a manual release from inside the trunk,
    situated behind the trunk liner.
    JW
    | project | 1993 Audi 80 VR6 turbo quattro |
    | daily | 2018 BMW G31 530d | 345bhp 770Nm |
    • B5NUT
      • Sep 2021
      • 1071
      I cannot remember there being one on my coupe, however you should be able to open the access flap and get your hand in there and pull on the actuator. If not then you will need to remove the side trim to get at the actuator.
        Pull the boot liner away and you'll see two bolt head that hold the actuator in place, take out the two bolts (I think m6 so 10mm socket) the actuator can then be pulled towards the back of the car which will release the flap.
        Alternatively fiddle a bit of vac tube onto the spare port of the actuator and suck
        • 4WDrifter
          • Nov 2012
          • 1251
          Thanks. I’ll let you know how I get on.
          • K Simmonds
            • Dec 2007
            • 7627
            Johns pretty much answered this, but it happened on my Coupe a couple of times so I've dealt with the issue myself... As he say's pull the drivers side boot carpet back, you can then access the actuator and operate it manually with a pick or screw driver.
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
            • Nuvo
              • Nov 2003
              • 3825
              I'm sure I was able to manually pull the actuator by hand without pulling away the boot trim. If you open the little carpeted flap for the screen wash and move the filler neck out of the way for access.
              Disclaimer: You might not be able to do this if you have hands the size of shovels.
              • K Simmonds
                • Dec 2007
                • 7627
                You're right Nuvo, this is possible, that's how I initially assessed the problem by have a peak though there with a torch, however I've got builders hands so I pulled the carpet to one side to actuate the mech manually though I think I could have done it through that flap at a push.
                1994 MTM RS2.
                2000 B5 TQS.
                  Yes I do have quite large hands
                  I think I'm going to slip a short bit of vac tube on the empty port which points towards the flap, then I can always open it with a Mightyvac
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    Mine decided it wasn't going to open when was I parked on a garage forecourt with 0 miles range displayed, so I didn't worry about using too much finesse I just wanted to put petrol in my car.
                    In my case the actuator itself had stuck but it really wasn't hard to active manually once I could see it.
                    1994 MTM RS2.
                    2000 B5 TQS.
