For those that have already installed a Reverse IM
a) Where did you ground the wires that were on side of the OEM inlet?
b) What core wire did you use to extend the various connectors?
c) What size hose is the it from the carbon cannister to the IM? Is it 8mm?
d) What size are the default tap size for vac nipples?
