Wagner Inlet Install Questions
This is a sticky topic.
    For those that have already installed a Reverse IM
    a) Where did you ground the wires that were on side of the OEM inlet?
    b) What core wire did you use to extend the various connectors?
    c) What size hose is the it from the carbon cannister to the IM? Is it 8mm?
    d) What size are the default tap size for vac nipples?
  • A80Avant
    • 10873
    • Country: Greece
    im subscribing on this thread.
    im going to need some info there myself.
    A friend of mine got me the IM on a good price so i will be probably using it on my next big upgrade!
    • GazzaG60
      • 4133
      mine came fully tapped. i used a rocker cover bolt ot earth one and i think the corner inlet for the other. wire was extended using a spare megasquirt loom i had.
      have a good check of the uinjector bores for rough edges etc.
      sedn me a pm if you want a pic. ill e-mail you one tomorrow, ill take apic at lunch if you need it.
      i am yet to mod the cruise to fit if thats your next q
      • A80Avant
        • 10873
        • Country: Greece
        i definitelly want the cruise!!
        • Lupo911
          • Apr 2005
          • 312
          a) Ground Wires with 8mm on the lower outisde bolt for the IM, 6mm Ground Wire goes on the 6mm Bolt of the 3b Distributor Cap
          b) 1.5
          C) 8mm
          d) M6
          • Sonic
            • Jul 2006
            • 5514
            And on an ABY?
            S2Forum.com Administrator
            • Lupo911
              • Apr 2005
              • 312
              Originally posted by Sonic
              And on an ABY?
              same Bolt
                Cheers, I wanted this on the forum as I could have easily got the answers offline
                • Henkjan
                  • 1705
                  thanks for asking
                  thanks for the answers
                  • s2martyn
                    Banned
                    • Apr 2008
                    • 408
                    re
                    i also need a few answrers to my inlet installation
                    1/what happens to the dipstick tube bolt?
                    2/does the pcv valve go to the manifold?or can i remove it?
                    3/will i get any errors not using carbon cannister?
                    does anyone have any install pics?
                    thanks martyn
                    • Sonic
                      • Jul 2006
                      • 5514
                      Been working on mine this evening also.
                      Just one question - the kit comes with a step-up hose to fit onto the intercooler inlet, im assuming ill need to cut back the samco and clamp a bit of tubing between the samco and new hose bit?
                        Good Reference
                        thread. Keep it going to cover all points.
                        Thanks for same.
                        • king
                          • Nov 2008
                          • 200
                          Originally posted by Henkjan
                          thanks for asking
                          What are you planning HJ? :mischeif:
                          • Lupo911
                            • Apr 2005
                            • 312
                            1/what happens to the dipstick tube bolt? that will mount to the ISV Valve Tube, only on ABY and ADU, 3B doenst need it
                            2/does the pcv valve go to the manifold?or can i remove it? no that goes to the Manifold, it will be mounted to the Same Tube like on the picture above
                            3/will i get any errors not using carbon cannister? No, errors, but our Manifold has the connector for the Carbon cannister...
                            thanks martyn
                            @Sonic, you are rigth, its just a Universal Part, because the most Guys are using different Turbos, its hard to make a Hose that will fit all
                            • s2martyn
                              Banned
                              • Apr 2008
                              • 408
                              re
                              thanks carsten....does the isv tube pictured come with the manifold or kit?my manifold has no hole for this to be fastened to!!
