Tachometer issue
  • Mr.Maki
    • Aug 2021
    • 3
    Tachometer issue
    Hi. I need help, a week ago my S2-92 started driving out of the garage and the tachometer suddenly stopped working, everything else works normally. have any of you had the same problem?
    • Dec 2017
    • 5983
    Try giving the dash a light thump just above the cluster.
    • Mr.Maki
      • Aug 2021
      • 3
      I did it but nothing happened. do you know where the signal to the tachometer comes from about the generator or the ignition coil?
        • Dec 2017
        • 5983
        Taken from G28 sensor on the side of the bell housing. Info here.
          • Dec 2017
          • 5983
          More likely damp in cluster and poor contact. Has the car been in the garage for long?
          Any mouse damage?
          • K Simmonds
            • Dec 2007
            • 7627
            Or try hitting it harder.
            1990 B3 2.0 80 quattro.
            1992 C4 2.8 Avant quattro
            1994 MTM RS2.
            1998 B5 TDI quattro Sport.
            2000 B5 TQS.
              There are two sets of long connecting pins in the cluster that can need resoldering to the circuit board, I’ve repaired a few.
              • K Simmonds
                • Dec 2007
                • 7627
                That'll be the problem then, very good info that John.
                1994 MTM RS2.
                2000 B5 TQS.
                • janglos199
                  • Mar 2022
                  • 4
                  Damn, it was so easy. I had the exact same problem. I went to the workshop with this issue. They claimed that they've replaced the board, ran diagnostics and did something else. They've charged me £200.
                    • Dec 2017
                    • 5983
                    Have you got a pic of the pins John?
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      I've got a couple of circuit boards knocking about in the house, could take a pic of one latter if John can't help, just having a quick break and a cuppa.
                      1994 MTM RS2.
                      2000 B5 TQS.
                        They’re the (25 or 30mm?) long pins that connect between the boards, they’re soldered to one board and slide into tiny individual sockets in the other board. The solder joints can go dry and things become intermittent, like the tacho or the speedo. It’s quite obvious if the joint has failed as the pin will wobble. Check the little socket too, use a dab of switch cleaner (caig de-oxit is fab) and, if you have some fine long nose pliers, you can very carefully squeeze the contacts to tighten them up a bit.
                        • Rikki Kitto
                          • Feb 2010
                          • 6276
                          Love this Forum was jus about to post a thread and found just what I need
                          • Rikki Kitto
                            • Feb 2010
                            • 6276
                            Mmmm solder looks ok not sure about this part of the board thoughps sorry for the hijack but thought pics might help you too
                            • K Simmonds
                              • Dec 2007
                              • 7627
                              It's hard to say from looking at the picture but that does look like a broken track, have you got a multimeter to test the circuit with? If your handy with a soldering iron they can be fixed by bridging the damage with fine wire, I'm never very happy with the results of this mind you.
                              1994 MTM RS2.
                              2000 B5 TQS.
