Hi. I need help, a week ago my S2-92 started driving out of the garage and the tachometer suddenly stopped working, everything else works normally. have any of you had the same problem?
Tachometer issue
Try giving the dash a light thump just above the cluster.Nothelle S2 Avant
Urs6 plus project gone -
Urs6 plus project goneComment
More likely damp in cluster and poor contact. Has the car been in the garage for long?
Any mouse damage?Nothelle S2 Avant
Or try hitting it harder.
1990 B3 2.0 80 quattro.
1992 C4 2.8 Avant quattro
1994 MTM RS2.
1998 B5 TDI quattro Sport.
2000 B5 TQS.Comment
There are two sets of long connecting pins in the cluster that can need resoldering to the circuit board, I’ve repaired a few.Comment
That'll be the problem then, very good info that John.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
Damn, it was so easy. I had the exact same problem. I went to the workshop with this issue. They claimed that they've replaced the board, ran diagnostics and did something else. They've charged me £200.Comment
I've got a couple of circuit boards knocking about in the house, could take a pic of one latter if John can't help, just having a quick break and a cuppa.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
They’re the (25 or 30mm?) long pins that connect between the boards, they’re soldered to one board and slide into tiny individual sockets in the other board. The solder joints can go dry and things become intermittent, like the tacho or the speedo. It’s quite obvious if the joint has failed as the pin will wobble. Check the little socket too, use a dab of switch cleaner (caig de-oxit is fab) and, if you have some fine long nose pliers, you can very carefully squeeze the contacts to tighten them up a bit.Comment
Mmmm solder looks ok not sure about this part of the board though
ps sorry for the hijack but thought pics might help you too
It's hard to say from looking at the picture but that does look like a broken track, have you got a multimeter to test the circuit with? If your handy with a soldering iron they can be fixed by bridging the damage with fine wire, I'm never very happy with the results of this mind you.1990 B3 2.0 80 quattro.
1994 MTM RS2.
2000 B5 TQS.Comment
