Jack4688's S2 Avant
  • Jack4688
    • May 2010
    • 1004
    Getting there:
    We got a little further than that before tucking it in for the night and my mate had to shoot off home. The drill bits sitting on the aux rad cover are for drilling out the screw that holds the rad to the panel over the top, that was the only issue we encountered..... so far
    While I'm this far in I'd better get the PAS pump off as I know it's leaking, having been replaced about a year before this one started leaking
    I may also take the wings off to get them looked at by a local independent body shop so that the car is as rust-free as it can be for the potential to export it to New Zealand with me.
    I managed to get almost everything that we took off inside the S2 but the bumper had to come inside the house - good thing there's no wife in the picture to annoy with those sort of shennanigans
    Oh and that used coolant makes for a tasty refreshment after a couple hours hard graft
    • Jack4688
      • May 2010
      • 1004
      Since changing that sensor I've run the engine a couple times letting it get up to temp no problem. Just needed it shifting on the drive this morning so I went to start her up but this happened:
      Forgive my ignorance if it's something obvious but I'm clueless as to what's going on there, can anyone help?
      • quattrostyle
        • Oct 2006
        • 6229
        Empty battery/loose cable?
        • Jack4688
          • May 2010
          • 1004
          Don't think the battery is empty because it's either been ticking over without starting or when it's been completely empty it has barely had enough power to turn the dash lights on when I turned the ignition. The battery did seem low so I put it on charge for a bit before I went out but it started pi$$ing down with rain when I got back home so I don't want to go back outside to connect it up
          I'll charge for a bit and see if it makes a difference...
          • Jack4688
            • May 2010
            • 1004
            Charging got rid of it - it must have been at that point in between refusing to tick over and refusing to start. But this time smoke was billowing out from the exhaust Last time it ran it was just a matter of getting rid of allllllll the condensation from the exhaust system
            • Ian_C
              • Oct 2007
              • 1008
              Could just be extra fuel being burnt away after being turned over but not starting
              B5 B6 B7 B9
              • Jack4688
                • May 2010
                • 1004
                Hopefully you're right about that! I'll give it a proper run later on this week when I get it proper warm for an oil change
                • Jack4688
                  • May 2010
                  • 1004
                  MOT (eventually) passed, now to sort boost leak or PAS leak
                  • hunker7
                    • Mar 2014
                    • 3487
                    #129
                    Read the whole thread and now I sort of want an S2 Avant Like the more square front on the S2 over UrS4
                    '93 Audi UrS4 Avant
                    '15 Audi A7 quattro 3.0 TDI
                    • Jack4688
                      • May 2010
                      • 1004
                      haha I sometimes hanker after a C4
                      • hunker7
                        • Mar 2014
                        • 3487
                        #131
                        Fancy a swap?
                        '93 Audi UrS4 Avant
                        • Jack4688
                          • May 2010
                          • 1004
                          Depends. How much rust is there? How much caked-on vegetation will I have to scrape/steam off? I ask because I want 5 cylinders when I move to New Zealand and this car is first choice at the moment although I need to sort out the rust and get rid of plenty of plant matter
                          • hunker7
                            • Mar 2014
                            • 3487
                            #133
                            I'm just joking around mate. Too much work has gone into mine to date to swap it around. I've sworn to myself I am not selling this one, just getting more.
                            And for the record, no vegetation on my car
                            '93 Audi UrS4 Avant
                            • Jack4688
                              • May 2010
                              • 1004
                              Don't worry me too, my Recaros wouldn't go in yours for a start
                              • hunker7
                                • Mar 2014
                                • 3487
                                #135
                                Everything fits into everything....eventually.
                                '93 Audi UrS4 Avant
