HELP! - Where does this fit???
  • HELP! - Where does this fit???
    All,
    I know this came off the area around the front of the engine cam cover area as I labelled it, but I can't work out where it fits back on, and my photo's don't document it.
    Help me and tell me where it fits back on please!
    I think it is around the cam position sensor wire connector, cam cover, cambelt cover area....
    The Perfectionist
    I can't really make out the P/N in the pic (nor do I own an AAN, but have your tried a Google of the number?
    Jase.
    Jason.
    24v VR6 Turbo powered B3 Coupe Quattro coming soon........
    Support our armed forces
      I tried deciphering it oo, but not quite, google it? There are a few sites that show these parts alongside the exploded parts diagram from the likes of oempc.
        Ok thanks, I will try with the part number later....
        I thought some genius would be along and just recongnise it and post up an image!
        The Perfectionist
          Many of us about, sadly google is still king in this department.
            Something to do with a heat shield?
              Is it ABY Steve?
                If it is the same as a 7A, isn't there a piece like that that stops the PAS belt flapping, and holds the cover?
                  Nearly but not quite..
                    Yes, I was thinking heat shield bracket at front of EM
                    Nothelle S2 Avant in restoration
                    Wr Ur Quattro (also in restoration)
                      This was what I was thinking of, so not that:
                        034 121 521 B - see this thread https://www.s2forum.com/forum/genera...this-part-goes
                        Mike
                        http://www.s2-audi.co.uk
                          Here you go Steve, I thought it was this.
                          It bolts to the head, the short leg holds the bottom of the exhaust manifold heat shield and the long leg steadies the turbo water pipe. (pretty sure there should be a clamp on there holding the water pipe..)
                            Originally posted by Mikes2 View Post
                            Hehe I was that genius last time even though I’d forgotten
                            • #15
                              First Prize! Thank you John.
                              The Perfectionist
