power amp problems
  • FRANK NITTI
    • Mar 2008
    • 107
    power amp problems
    I put a direct amp D2400 in an audi coupe with 2 12inch jl speakers and the amp was constantly cutting out - wiring was checked and was fine. Had amp sent off for testing and they put it on the bench and said amp is fine. The put the same amp in my s2 and same thing keeps happening until it completely cut out and all the fuses melted. Now i bought hcaa orion 12 inch single speaker and orion d2400 monoblock amp to drive it. amp is cutting out again! Took it back to shop - they did tests which showed everything was fine but then swapped for alpine amp to see if it would make any difference . Next day showed my friend the new amp and it cut out ! Took it back and got my orion back as i prefer it. Seems like these cars are allergic to loud music ! Or am I jinxed. My s2 has 120 alternator so what is the problem??!!! Is there a power problem.
    My electrician said he will try to solve this and he said dont spend money buying a power cap til problem properly diagnosed but he is puzzled himself....
    My alternator was reading 1368 when the amp is off then drops down to 1290-1306 with amp kicking
    This was my boss and I know for a fact if he was around today he would be driving a sick ABY armour plated S2 1500 bhp....
  • Bowlerwell
    • Sep 2005
    • 1052
    Does the amp still cut out when only up half volume?
    (or is it perminantly on 11?)
    John Bowlerwell
    Electronic Engineer
    Present:
    Nogaro Blue RS2 - TOE
    Previous:
    Kingfisher Blue S2 - UAA
    Volcano Black RS2 LHD - DEX
    • FRANK NITTI
      • Mar 2008
      • 107
      the head unit can go up to 50 but it will cut out at 10, 15, 20 - it doesnt always turn on remotely when you switch on the head unit so what i do to resolve this even when it does cut out as well is give the amp a slap and it gets going ! this is annoying when you wana go somewhere and it cuts out coz i hav to get out my seat and climb to the back of the car at a red light! Used to do the same for the other amp too - i swear its coupes that dont like a system in them..!
      • FRANK NITTI
        • Mar 2008
        • 107
        believe me - i dont understand this - its a weird one - all i wana do is listen to music but i have to play musical chairs in my own car!
          Who gives these people a driving licence??
            Just kidding, sounds like you have a bad connection, either power or ground, where are you taking the power from and where are you grounding to?
            • Bowlerwell
              • Sep 2005
              • 1052
              What's the power supply requirement for the amp? (in current or power)
              John Bowlerwell
              Electronic Engineer
              Present:
              Previous:
              • Big Lee M
                • 2571
                It could be a bad conection or even overheating?
                Just some finishing touches to do now
                • anton
                  • Jan 2005
                  • 802
                  could it not be the remote signal from the headunit?
                  Ant
                  91' Coupe quattro 20v - project
                  KW V2s and other goodies
                  now gone
                  03' BMW 330CI - Sold
                  08' A5 Coupe 3.0l tdi quattro - Sold
                  57' BMW 525d M Sport Touring
                  • Fat Audi 80
                    • 10547
                    I have had similar problems and it was the earth cable not up to the job and not grounded to the car body correctly. I would carefully check your earthing requirements and the way you have it connected.
                    HTH
                    Cheers.
                    Steve.
                    The Perfectionist
                    • FRANK NITTI
                      • Mar 2008
                      • 107
                      remote signal from headunit........probably not as also has the same problem with a different head unit!
                      bad connection or overheating.......wiring has been checked and tested - seems fine - amp doesnt get that hot
                      power supply 12V
                      Im taking the power from the battery and grounding to the chassis
                      thanx
                      • Bowlerwell
                        • Sep 2005
                        • 1052
                        What's the power requirement in power, or current?
                        John Bowlerwell
                        Electronic Engineer
                        Present:
                        Previous:
                          You need to use a volt meter and check the voltage on the terminals of the amp.
                          The voltage on the REM, and the voltage at the amp.
                          Also what gauge wire are you using? Because it also sounds like your wiring could be too small and the current demands of the amp are not being met.
                          BTW you alternator should be putting out over 14 volts when the engine is running.
                          • S4 CRUISER
                            • 60
                            !st of all you need to make sure u got 4guage cable into the amp. The earth should be 4 guage as well. If you are using 4guage cable change ur earth point. Where are your amp gains set to?? If they are over half turn them to min and then test it. Measure your sub coils make sure they are not short. Are u connecting the subs correctly to the amp??
                            • FRANK NITTI
                              • Mar 2008
                              • 107
                              just 2 update - my electric guy came round and tested all wiring on car and power, remote fine, voltage fine - turned up to 30 and it cut out ! so he says it must be the amp - but what r the chances of 3 diff amps being faulty...?!! wot a pain in the rear end!
