I put a direct amp D2400 in an audi coupe with 2 12inch jl speakers and the amp was constantly cutting out - wiring was checked and was fine. Had amp sent off for testing and they put it on the bench and said amp is fine. The put the same amp in my s2 and same thing keeps happening until it completely cut out and all the fuses melted. Now i bought hcaa orion 12 inch single speaker and orion d2400 monoblock amp to drive it. amp is cutting out again! Took it back to shop - they did tests which showed everything was fine but then swapped for alpine amp to see if it would make any difference . Next day showed my friend the new amp and it cut out ! Took it back and got my orion back as i prefer it. Seems like these cars are allergic to loud music ! Or am I jinxed. My s2 has 120 alternator so what is the problem??!!! Is there a power problem.
My electrician said he will try to solve this and he said dont spend money buying a power cap til problem properly diagnosed but he is puzzled himself....
My alternator was reading 1368 when the amp is off then drops down to 1290-1306 with amp kicking
