Mk 2 golf digifant miss fire
  • rj scotty
    • May 2006
    • 2195
    Well I say miss fire it's fine on tick over but will not rev beyond 4K and juders along badley. Plugs, Cap, Roator and leads all good. So lets start guessing:
    Coil braking down?, it is 21 years old.
    Fuel pump issue?
    Keep the guessing coming.
    cheers
    rich
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
  • pixsaudisex2
    • Sep 2004
    • 3110
    id say fuel pump.. not enough pressure. had this happen once or twice and the only other thing i ever seen do this was an injector leaking.. my 2 pence..
    • rj scotty
      • May 2006
      • 2195
      Best way to test fuel pump ?
      • pixsaudisex2
        • Sep 2004
        • 3110
        undo the pipe some where ( under car by the pump.) An check if it is under much pressure,, much much super spray. Remember someone had the black box the pump goes in split once also..
        • rj scotty
          • May 2006
          • 2195
          Tomorrow morning job then, now what can I rob a fuel pump off :mischeif:
          • 3b_aby
            • Jun 2009
            • 67
            • Home: Scotland Current: Singapore
            air flow meter?
            try some carb spray, check connections?
            • rj scotty
              • May 2006
              • 2195
              Worth a look as I have just been for a drive and all is well
              I think a general tune and check over tomorrow if I can get the garage warm
              • quattronutter
                • Jan 2005
                • 690
                broken woodruff key on crank pulley can cause similar problems
                • rj scotty
                  • May 2006
                  • 2195
                  will look at that too
                  • rj scotty
                    • May 2006
                    • 2195
                    OK this getting worse but I'm now almost sure it's a fuel starvation issue.
                    I bypassed the fuel pump relay today and drained the whole tank into a jerry can all the time observing the flow, no bubbles or change in the flow occurred at all.
                    I'm now thinking this is a simple electrical fault in the supply to the pump as I have never heard of a fuel pump with an intermittent fault, they either work or they don't in my experience.
                    I'm going to change the fuel pump relay and I'm thinking of doing two things:
                    1. Temporarily fitting a fuel pressure gauge inside the car.
                    2. Temporarily running an indicator lamp from the pump terminals.
                    This would allow me to diagnose the pump or a loss of 12V supply agree?
                    Dose any body have a fuel pressure gauge I could borrow?
                    cheers
                    rich
                    • BRY
                      • 3755
                      Coil, its easier to swap than everything on the fuel side - I know as I did it all on my mk1 before I swapped the coil.
                      At 21 years old it won't be doing it's best anyway
                      • quattronutter
                        • Jan 2005
                        • 690
                        coolant temp sensor maybe
                        • rj scotty
                          • May 2006
                          • 2195
                          Defiantly feels like fuel starvation to me as it will barely idle and gets worse when you open the throttle.
                          Remember this only happen intermittently and will fix it's self in a flash.
                          Totally agree with you regarding coil I'm going to change regardless.
                          As for temp sensor they run rough as hell when that is disconnected/at fault and won't idle.
                          • rj scotty
                            • May 2006
                            • 2195
                            Just as a side not this issue means I have to use the s2 for work for this week.
                            Not going to earn any money due to mpg !
                              Wiring to the pump is notoriously flimsy, would be worth sticking a relay near the pump with a decent feed from the battery via a fuse and using the old wiring to switch it, did this on the ur and got another 3 volts at the pump.
                              Also, if you have an alarm/immob which breaks the fuel pump circuit, bypass that part of the immob and remake that circuit properly.
                              Also, did you empty the tank through the filter?
