These ones are 0.5" up and at 90 degrees to the pin.
JE Pistons Group Buy
I'd let the machine shop work out the clearance. Just give them the pistons and any clearance instructions and let them do the rest.Originally posted by Doug_RS2These ones are 0.5" up and at 90 degrees to the pin.91 Modded 3B
14 A6 Avant Black EditionComment
Side 1Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
Side 2Attached FilesS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
I just got this from Steve:
Dougal,
Measure the piston diameter .500 up from the bottom of the Piston....Set the Piston to Wall clearance .0035" from that diameter....
Steve
But I think you should add 0.001 to 0.003" becasue you are running NOS - that's what I understand from the instructions.
Can you measure you pistons - I hope you have the same diameter as us and they haven't given you slightly smaller to take into account your NOS - then you might get away with larger boresS2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
Received mine today, very nice they are too, they will look very nice on the end of my Arrows
, shame that they have to be locked away inside a block
Should hopefully get things moving now with the rebuild.
Big thanks to Doug and Dave (Desmo) for the work they put into this Group buy, I know it must have been a PITA at times getting things sorted.....cheers fellas
Mark.Mark - ModdedComment
