Group Buy Interest - Billet Crankcase Breather - 054 103 129
  • RichLV
    • Mar 2015
    • 872
    • Country: Latvia
    #46
    I've been following this for some time and I'm interested, but I still don't understand the purpose of it. It removes the need for a catch-can? Or is it supposed to work in conjunction with one? Maybe I'll be interested in purchasing one if I understand the purpose of it.
    • Wizard-of-OD
      • 926
      • Home: Syria Current: Canada
      #47
      The OEM part is literally a cup with a sheet of metal in the centre of it. It really does not "baffle" like more modern VAG engines. Also when it needs to be replaced , you pretty much damage the part. My solution will allow 1 fixed piece to be installed and the 2nd component can be removed/reinstalled for servicing at any time without damaging any components
      it is designed to be used with either a catch can or the OEM hoses.
      Issam N. Abed
      iABED Industries
      iABED Email | Facebook
      The build thread
      • RichLV
        • Mar 2015
        • 872
        • Country: Latvia
        #48
        I suppose the shipping is form Canada? I'm a bit busy with other engine stuff at the moment. Will another run be made some time?
        • Wizard-of-OD
          • 926
          #49
          US or Canada depending on whatever is cheaper.
          This will be the only run.
          Issam N. Abed
          iABED Industries
          The build thread
          • RichLV
            • Mar 2015
            • 872
            • Country: Latvia
            #50
            Pity... Oh well...
            • varia
              • 821
              • Current: United States
              #51
              Issam, i need one as well. Thank you!
              • goodall
                • Jul 2008
                • 810
                #52
                Originally posted by Wizard-of-OD
                Recenetly finished up the Crankcase breather unit for the TDI's
                Also revised the assembly to be a little cheaper to machine. Will get this going shortly as well. Need to finalize a quote for laser cutting the baffles from SS.
                Tell me more about these, I currently run a 2.5tdi I5 and I need a breather as one I took of a non turbo 4 cylinder Peugeot just ends up pressurising the crank case it plugged in
                • varia
                  • 821
                  #53
                  1.Wizard-Of-OD
                  2.Wizard-Of-OD
                  3.Tonks4x4
                  4.Tonks4x4
                  5.Tonks4x4
                  6.Tonks4x4
                  7.Tonks4x4
                  8.europeanm
                  9.ringbearer
                  10.AndyP
                  11.Henkjan
                  12.mac2226
                  13.ash2050
                  14.Error404
                  15.AMDisthebest
                  16.AMDisthebest
                  17.inne3quattro
                  18.EFIX
                  19.EFIX
                  20.EFIX
                  21.EFIX
                  22.EFIX
                  23.burns_21
                  24.butchone
                  25.cypres83
                  26.jsol
                  27.gc77
                  28.VagOrBust
                  29.VagOrBust
                  30. varia
                  • Wizard-of-OD
                    • 926
                    #54
                    Daniel Terre - PAID
                    JSOL - PAID
                    Issam N. Abed
                    iABED Industries
                    The build thread
                      #55
                      HTH Issam and other members.
                      If you put '054103129 photo' into Google, it will display a load of photos, the early ones in the array of photos, show both sides of the oem piece and also photos show where it is located on the I5 block. In behind the after-run pump towards the flywheel area.
                      Another shows the hole it is mounted into on a used block.
                      As I say HTH a bit.
                      • VagOrBust
                        • Feb 2010
                        • 107
                        • Home: Netherlands
                        #56
                        Originally posted by Henkjan
                        Ok. is it OK to set deadline at the end of next week?
                        Hello Henkjan. Have you managed to contact the others in the shipment group?
                        I'll wager Issam is keen to get this going and I've got the money ready to go.
                        5 cilinder addict:
                        1995 UrS6, 2.2 turbo, daily driver, EFI coilkit, custom exhaust.
                        1993 S2, 2.2 turbo, ABY, long term project.
                        2006 Ford Fiesta 1.4 TDCI. Because reasons.
                        • Jelle..
                          • Mar 2012
                          • 52
                          • Home: Netherlands
                          #57
                          I like to have one, can i still join the groupbuy?
                          • Henkjan
                            • 1705
                            not all yet, been a bit too busy with work I'll get on with it in the weekend
                            sure!
                            • Jelle..
                              • Mar 2012
                              • 52
                              • Home: Netherlands
                              #59
                              1.Wizard-Of-OD
                              2.Wizard-Of-OD
                              3.Tonks4x4
                              4.Tonks4x4
                              5.Tonks4x4
                              6.Tonks4x4
                              7.Tonks4x4
                              8.europeanm
                              9.ringbearer
                              10.AndyP
                              11.Henkjan
                              12.mac2226
                              13.ash2050
                              14.Error404
                              15.AMDisthebest
                              16.AMDisthebest
                              17.inne3quattro
                              18.EFIX
                              19.EFIX
                              20.EFIX
                              21.EFIX
                              22.EFIX
                              23.burns_21
                              24.butchone
                              25.cypres83
                              26.jsol
                              27.gc77
                              28.VagOrBust
                              29.VagOrBust
                              30. varia
                              31. Jelle..
                              Can i join the NL shipment group, henkjan?
                              • Henkjan
                                • 1705
