Audi C4 S4 extra front caster ARB mounts
  • JP
    • 1858
    Just waiting for arb to be epoxy painted and then mines fitted with new lower arms and bushes. Can take a pic when done if desired be later this week. You'll need to drop front subframe to undo old one.
    I also noticed that the main bush that locates the lower arm to subframe was tearing out of its metal sleeve when removing and changing over yesterday so looking forward to the poly upgrade
    UrS6 Stroker + HTA3586 =
      #92
      Thanks JP.
      Keen to see how you get on before I tackle mine.
      • orignalS60
        • Mar 2015
        • 792
        • Home: Croatia Current: United States
        #93
        @macspring I was just agreeing with you
        that it would be cool to see some pics of
        these installed. My phone put the wrong
        damn emoji thing lol.
        @Albert, thanks!
          #94
          at orignalS60, grand, no worries, makes sense now.
          • A1QSHIP
            • Aug 2004
            • 975
            Parts have arrived this day. Thanks Albert!
            "Nulla tenaci invia est via"
            • Albert
              • 1500
              • Country: Poland
              #96
              AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
                #97
                Albert, can you advise what bolt length and diameter you recommend for the installation of the new brackets ?
                You might consider offering the bolts, nuts and washers as an extra for future customers, as this is what is stopping me from installing mine - lack of time to source same.
                • Albert
                  • 1500
                  • Country: Poland
                  #98
                  It should be M12 and 65 mm in lenght
                  pics bellow for correct poli fitting
                    #99
                    Thanks for the reply Albert, will look to get the bolts this week. Photo to affirm the orientation of the of the bush is timely also.
                    • Albert
                      • 1500
                      • Country: Poland
                      #100
                      just to double post, you need this type of the screws. L = 65 mm
                      • diesel des
                        • 3896
                        #101
                        Do we need anything else like nuts or washers?
                        • diesel des
                          • 3896
                          #102
                          Oh and we call those cap head bolts as they take an Allen key hex bit.
                            • 4754
                            M12 fine but what about tensile strength?
                            • diesel des
                              • 3896
                              #104
                              Oh are they fine?
                              • orignalS60
                                • Mar 2015
                                • 792
                                #105
                                Albert can you post a link for a good
                                source of the hardware?
