An alternative to the IC O-ring
This is a sticky topic.
  • #46
    Ok, how do you remove the front bumper please? 3B...
    • #47
      Indicators
      Fog lights
      Screws in wheel arch - Nasty
      Bolts behind fog lights
      Unclip from undertray
      Fight with headlamp washer hose to remove it, then decide to leave it connected.
      Don't attempt it on your own first time.
      Easy
      • #48
        soak threads of bolts in wheel arch for a week in WD-40, turn wheels on full lock to remove them, indicaters/fogs out two bolts each side behind fogs 13mm socket IIRC on a long extention,
        use a friend or the mrs to hold the other side of the bumper while you pull it off,
        alot easiyer to put back on if you have someone to help you
        HTH
        Will
        • #49
          Bry you are on the ball this morning!!
          think i pulled the pump out of the washer bottle on the head lamp washers as everything was grown on!
          • #50
            Indicators
            Fog lights
            Easy
            But i have no one to help, well the mrs but she dosent like getting her hands dirty
            Chef
            • #51
              Tell her how much your paint costs, and if she doesn't help you'll be needing both your front wings doing as the bumper gently takes the paint off when it rolls forward.
              • #52
                Chef
                • #53
                  I did it myself by sitting on the ground supporting the bumper with my legs. Worked for removing and refitting. Obviously, have everything undone except one bolt on each side.
                  ex '93 Avant owner
                  • #54
                    Similarly I just use a toolbox to rest one side of the bumper on, plus my legs . I don't bother asking the wife - the toolbox is far more helpful. I've found no need to usually undo the washer hose - just lie the bumper down on a suitable bit of cardboard or rug etc. next to the car.
                    nigelm
                    • #55
                      Can't believe how stupid I've been to not do this earlier.. >: thanks anyways Mark H!
                      Andreas Lundstroem
                      A4 STCC Avant -04
                      Audi /S/2/ Sedan -94
                      prev.
                      Audi /S/2/ Coupe -91
                      • #56
                        Bump
                        • #57
                          I have readed about Mark H mod. How to make sure this O-ring is leaking and needs this mod?
                          • #58
                            Pressure test intake
                            Tom C - www.rcmr.co.uk
                            Audi UR Quattro
                            Audi 100 C3 2.0 5 cyl 115ps
                            Audi B5 RS4 645ps 911nm
                            • #59
                              Deserves a bump!
