Ok, how do you remove the front bumper please? 3B...
An alternative to the IC O-ring
This is a sticky topic.
Indicators
Fog lights
Screws in wheel arch - Nasty
Bolts behind fog lights
Unclip from undertray
Fight with headlamp washer hose to remove it, then decide to leave it connected.
Don't attempt it on your own first time.
EasyKingdoms are run by Kings, Dictatorships are run by Dictators.
soak threads of bolts in wheel arch for a week in WD-40, turn wheels on full lock to remove them, indicaters/fogs out two bolts each side behind fogs 13mm socket IIRC on a long extention,
use a friend or the mrs to hold the other side of the bumper while you pull it off,
alot easiyer to put back on if you have someone to help you
HTH
Will
Indicators
Fog lights
EasyChef
Originally posted by terrybullwonBut i have no one to help, well the mrs but she dosent like getting her hands dirtyKingdoms are run by Kings, Dictatorships are run by Dictators.
Originally posted by terrybullwonBut i have no one to help, well the mrs but she dosent like getting her hands dirtyex '93 Avant owner
Originally posted by SidspudI did it myself by sitting on the ground supporting the bumper with my legs. Worked for removing and refitting. Obviously, have everything undone except one bolt on each side.
Similarly I just use a toolbox to rest one side of the bumper on, plus my legs . I don't bother asking the wife - the toolbox is far more helpful. I've found no need to usually undo the washer hose - just lie the bumper down on a suitable bit of cardboard or rug etc. next to the car.
nigelm
Can't believe how stupid I've been to not do this earlier.. >: thanks anyways Mark H!Andreas Lundstroem
A4 STCC Avant -04
Audi /S/2/ Sedan -94
prev.
Audi /S/2/ Coupe -91
Pressure test intake
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm
Deserves a bump!
- 1 like
