Yup, only the sleeves are longer - you will see them compress a bit when you tighten up the bolts onto the car.
you'll like them - they're a good ride, tight but not too harsh
And finally - just a snap for reference of the correct orientation of wishbone bolts. Torque setting on these is 40Nm plus 180 degrees. Not easy to do on the ground...
Paul
UPDATE - I have just realised the attached pic is labelled wrongly. This wishbone is actually from the opposite side and therefore FRONT and REAR should be swapped over as well. Sorry for any confusion - will try to dig up original pic and rectify labels.
I'm fitting S2/cast front arms to my CQ, trying to figure out which side is which and which ball-joint goes on which side.............I thought all I had to do was check this thread.....clear as mud!!!
Can someone tell me which side the arm in the pic belongs to, and is the ball joint pointing the right way.
Cheers.
