Alternative head stud washer solution to ARP's.
  • AndyP
    • 6049
    Originally posted by andy10v
    What torque is everybody using?
    JP said the digging in is due to lack of lube and the washer turning.
    That picture is for the 11mm stud used on the stroker engine, don't use that torque value on a 2.2 engine
    • Thuppu
      • 4115
      This one uses my washers(ID 12mm, OD 24mm).
      • SteveH
        • 4460
        Damn that's a big turbo!
        91 Modded 3B
        14 A6 Avant Black Edition
        • SteveH
          • 4460
          My ARP's have these torque values. I've assumed it's the 'B' option for aluminium.
          91 Modded 3B
            Thuppu washers FTW!
            • SteveH
              • 4460
              Well I've inquired about the Toyota washers and they are on order from Japan if you want them in the UK. Two weeks minimum to get them here!
              91 Modded 3B
              • Audi_CQ
                • 940
                • Country: Norway
                #22
                For strokers with 2.5 Block and 12mm studs. 12mm with 25mm OD so may need a bit of machining:
                http://arp-bolts.com/kits/ARPkit-det...?RecordID=1065
                • michaels2s
                  • Nov 2012
                  • 87
                  Hey guys
                  You can also use the washers of the VW T5 2,5 TDi
                  Part Number : N 901 157 01
                  Also a good choice
                  Diameter : 12,5x23x4,5
                  [__]=oooo=[__]
                  • AndyP
                    • 6049
                    Seems I was talking bo**ocks with that previous post, ARP just changed the torque spec from 65 to 85ft/lb
                    • SteveH
                      • 4460
                      I'll go 75 then to be safe!
                      91 Modded 3B
                      • rxl
                        • 1913
                        did mine to 70 but i gues i gonna retorque them to 85 after first heat cycle..
                        • quattro84
                          • Mar 2006
                          • 947
                          BMW washers can be used as well, hardened and grinded. (1112)1265388 fitted on older M20's until the newer IL4's.
                          • zafra
                            • Jun 2013
                            • 320
                            • Country: Spain
                            #28
                            Someone use the toyota washers?? Need modified??
                            Step 1: setup. <==
                            Step 2: potentiation.
                            Step 3: enjoy.
                            • zafra
                              • Jun 2013
                              • 320
                              • Country: Spain
                              #29
                              toyota washers are perfect, finally i use that.
                              Step 1: setup. <==
                              Step 3: enjoy.
