Alternative head stud washer solution to ARP's.
My ARP's have these torque values. I've assumed it's the 'B' option for aluminium.Attached Files91 Modded 3B
14 A6 Avant Black EditionComment
For strokers with 2.5 Block and 12mm studs. 12mm with 25mm OD so may need a bit of machining:
http://arp-bolts.com/kits/ARPkit-det...?RecordID=1065Comment
Hey guys
You can also use the washers of the VW T5 2,5 TDi
Part Number : N 901 157 01
Also a good choice
Diameter : 12,5x23x4,5[__]=oooo=[__]Comment
Seems I was talking bo**ocks with that previous post, ARP just changed the torque spec from 65 to 85ft/lb
1976 RD250E / 350LC cafe racerComment
