RS2 restoration near completion
  • joss01
    • Apr 2019
    • 384
    My measurement is 90mm with the original springs fitted with new bilstein shocks I wonder if they have sent the wrong shocks because everything else is correctly fitted
    • steve briance
      • Aug 2014
      • 1455
      Shocks won't affect ride height. If you've used the original springs I'd not expect it to settle too much. See if your top mounts are on the right way round...
      • John.
        • 2615
        Is there not a thread somewhere about Bilstein shocks having to have another groove cut into the body??…….or something to that effect?
        • steve briance
          • Aug 2014
          • 1455
          Are you thinking about the drain holes in the bottom of the strut?
          • joss01
            • Apr 2019
            • 384
            No thread the B6 shocks are set no adjustment
            • saltinot
              • May 2004
              • 1946
              #21
              On the rear Bilsteins you will need lower the bottom spring perch by having a machine shop add a groove beneath the original groove. There has been some debate as to the distance below the original perch. I did this a while back and there is some info on my RS2 America thread as well as other threads. If my memory serves me I think I chose to move mine 20mm down. Others chime in to keep keep honest.
              • joss01
                • Apr 2019
                • 384
                I may as well buy a pair of original Borge rear shocks it would be cheaper and and work first time
                  Ah yes the Avant rear is like a coil over with a fixed lower perch
                  • joss01
                    • Apr 2019
                    • 384
                    yes it has a flange at the base of the shock that retains the spring
                    • joss01
                      • Apr 2019
                      • 384
                      You really don't want to be doing this job on a rainy Saturday after getting the engine running right bought the car up to temperature and it was like a steam room inside the car after I switched it off so the dash had to come out to replace the heat exchanger horrible job but after you have you've done it its quite rewarding definitely a challenge.
                        • Dec 2017
                        • 5983
                        Not a nice job at all.
                        Don't forget to change the foam on the flaps as that will be past it!
                        • joss01
                          • Apr 2019
                          • 384
                          yes put all new foam on the flaps the original ones had turned to dust
                          • joss01
                            • Apr 2019
                            • 384
                            Today I fitted the bottom door trim the cillm and the inner door cill mappings fullsizeoutput_828.jpegfullsizeoutput_828.jpeg
                            • joss01
                              • Apr 2019
                              • 384
                              All the interiors in now still trying to work out the Audi Gamma cd player I was told it is a passive headset and requires an amplifier
                                • Dec 2017
                                • 5983
                                I have a spare set of axle stands you can have when I'm passing next mate!
