B4 2.6 quattro Avant with factory Sport suspension.
  • Alburglar
    • Oct 2017
    • 63
    Those engine codes have cut and paste weird but basically:
    Audi A4 B5 quattro 1.8t conversion, Engine code: AJL 180bhp does seem to be the favorite, as you suggest Dave.
    Audi
    AJL Or AEB, ATW, APU or AMB, ARK, AVJ, AWT, BEX, BFB
    AMB must be an 058 block, NOT an 06A block.
    058 Block: external water pump
    06A Block: internal water pump
    VW
    ANB, APH, APU ATW AWM
    Audi and VW
    AWT ATW
    • ak139
      • Mar 2020
      • 13
      Cabrio ADR engine mounts fit the 058 block
      Originally posted by Alburglar
      Both AJL and AEB have preferred 20mm piston/ rod wrist pins (rather than 19mm), cast crank, large port head, external water pump and IM shaft driven oil pump.
      there is a chance finding a forged crank in an early ones
      • Alburglar
        • Oct 2017
        • 63
        Went to pull all the door cards off to get new foam the vinyl reattached and found something very interesting.
        • Alburglar
          • Oct 2017
          • 63
          Driving round like this with all four doors cards off is very noisy!
          • Alburglar
            • Oct 2017
            • 63
            One of these clips is missing from the driver's front door. It stops the door pull outer cable from popping out. Anyone know where to get them?
            • Alburglar
              • Oct 2017
              • 63
                Part number 893837073
                https://www.ebay.co.uk/itm/135492590899
                • Alburglar
                  • Oct 2017
                  • 63
                  Perfect Thanks
                  ...well almost perfect. Tenner a clip. Wow
                  • Alburglar
                    • Oct 2017
                    • 63
                    Just found them, with that part number, for 0.77 euros each, but with £14.99 delivery from Europe. Lol, still cheaper.
                    https://www.oemvwshop.com/893837073-clip-p1092686/
                      • Dec 2017
                      • 6015
                      Why don't you order a few then sell some on the forum to cover your postage. You can put me down for two
                      • Alburglar
                        • Oct 2017
                        • 63
                        Postage is a month!, but I have emailed them to see how many they have got.
                        • Alburglar
                          • Oct 2017
                          • 63
                          Sometimes one job turns into another.
                          Fuel sender died. Came back to life. Died again.
                          Pulled it out (part number 8A0919051C for my own future reference in case it dies)
                          The wire that usually breaks, from the moving float arm of the sender was fine...
                          • Alburglar
                            • Oct 2017
                            • 63
                            Luckily I have the perfect fuel send testing station. Resistance was 40.7 full, to 198.9 low,.then it must go open circuit or something when empty, and that must send the signal to the warning light. As it goes 198 then jumps to a 1.
                            So that's working fine it seems...
                            • Alburglar
                              • Oct 2017
                              • 63
                              So I've tweaked these metal arms (there's one each side) that hold the contact that swings with the float arm, in the hope that it was making a weak contact and I've increased the pressure slightly. It is currently back together and working. Fingers crossed.
                              • Alburglar
                                • Oct 2017
                                • 63
                                The reason is it turned into another job, is that I thought the sender would be under the rear seat. (It wasn't, it was in the boot). But I decided to give the interior a hoover before I started. It was then I discovered the offside floor was soaking wet.
                                Pain in the **** cos I bought the car with a soaking wet passenger side floor (years ago) and whilst chasing that issue (which resulted in dash out and new heat exchanger) I had bought some strimmer plastic wire and with WD40 cleared out the sunroof drains. So I was thinking what on earth is that gonna be?
                                Luckily it was simple. The fuse box lid,.under the bonnet, was completely off! I swapped a fuse the other day in terrible weather at the side of the road. I definitely put the fuse box lid back on, but obviously not located properly on the hinges/pins and the back and it's popped open at some point.
                                The fix is obviously "put the lid on properly next time you wally" but to dry the floor out: old tights full of silicone cat litter worked wonders last time...
