Jesus Greg your really putting me off long term ownership of the S2!
Very Scary
Is that body parts Mark??sigpic
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nmComment
Over £3000 this year so far and I haven't modified it!The Perfectionist
Is that the noise the pistons are for mark? what is the problem- bad machining or piston probs???Originally posted by Mark HalliganLOL yeah that seems to work with me, but there is no way I will add it all up.....nope, no way, I just couldn't.
Just had to order another set of pistons to sort out my problem, but have almost managed to raise enough for them by selling parts, which kind of takes the pain away...................not
I spent £15000 on my last S2 (not inc buying) and think the new one will cost that again even with the sale of the last + parts!!
Greg - that includes an engine rebuild - that is where alot of money goes - you should have gone a bit further and got the uprated rods in there at the same time.
I reckon I would be double what you have spent Greg - but that is over 3 years.S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
Ive spent just over £4k on mine in just over 2 years, considering what ive done i dont think thats too bad. But i think if you have spent loads on upgrades etc the value of your car will have risen too, which is no way near as bad as spending thousands and still ending up with a standard car which is worth less than you paid for it.Comment
Originally posted by JayIs that the noise the pistons are for mark? what is the problem- bad machining or piston probs???
It is a machining issue, Doug is running the same pistons from the same production run and has no slap. I have ordered another set of JE's with a few differences to spec.
This time I will measure the pistons myself and work out the correct bore size have it bored/honed to that, at least then if it goes wrong I can't whinge about it.Mark - ModdedComment
Are the specs for machining J E's pistons his or audis? if the piston material/ design differ there could be an issue (high silicon don't expand much etc)Originally posted by Mark HalliganIt is a machining issue, Doug is running the same pistons from the same production run and has no slap. I have ordered another set of JE's with a few differences to spec.
Also you need to spec the honeing finish again get direction of JE if possible (pick a road spec not race if you want any ring life and no blow-by, run it in properly e.g no extended bursts of high speed (temps rocket), keep moving the throttle open and closed so you push the rings out on acceloration then draw up oil to cool/lubricate on a closed throttle- cause a vac in the combustion chamber and reseat the rings)
JayComment
106 566.79SEK is 8218.3GBP so you're a bit ahead of me. =) Though the lastest stuffs ain't added and theres more to come.
Originally posted by Greg_SI had an hour spare this evening and decided to add the receipts up on what I have spent on my car since I bought it in 2002 and I am very surprised how much I have actually spent.
When I got it i said I would keep it repiared etc regardless of cost which I have done. I have missed a few receipts off of this tonight which I had missed, but I am amazed at what i have spent, the total I have spent on parts is......
£9224
Greg/NEO - I have a sexual thing for big brakes.
www.irry.com | Irry got a face lift!
#nordicaudi @ irc.nordicaudi.comComment
Mostly small stuffs like sparkplugs and so. Though I see now that the latest paintjob ain't in the list. Seems like I have to update. =)
Edit: Updated the list... 118 862.30SEK = 9166.52GBP
Originally posted by Greg_Swhat have you just bought for yours?
GregLast edited by NEO; 13 December 2004, 22:59./NEO - I have a sexual thing for big brakes.
I reckon I'm in about 10k too, including the car.
Denial is a river in Africa, right?Comment
Including the car? =) well... Then I'm up to:
266662.30SEK = 20564.68GBP
Total madness... But there's no turning back. =/
Originally posted by newshI reckon I'm in about 10k too, including the car, of course denial is a river in Africa, right?/NEO - I have a sexual thing for big brakes.
