Resurrection of my UrS4 2.2 turbo 20V quattro AAN Avant
  • marius555
    • Apr 2012
    • 126
    • Country: Romania
    #46
    Well , he's not interested because he isn't using too often the break pedal
    • Nick320
      • Nov 2013
      • 52
      • Home: Bulgaria Current: Canada
      #47
      That's funny
      • wug
        • Oct 2014
        • 165
        • Country: Romania
        #48
        Uhm, for the moment brakes are stock. New rotors, pads and hoses 1 year old. I think for the power i have right now are good enough. Like Marius said, using brakes on this car is no fun at all.
        UrS4 "PK Motorsport"
        • A1QSHIP
          • Aug 2004
          • 975
          Where did you source the fuel pump inlet filter from?
          "Nulla tenaci invia est via"
          • Majorcina
            • Jun 2013
            • 1334
            • Country: Montenegro
            #50
            Dont know how i miss this,great work mate! Car looks good
            One question: Why did you change from walbro to bosh 044?
            • wug
              • Oct 2014
              • 165
              • Country: Romania
              #51
              @A1QSHIP I got this from here. I also got this part as well.
              @Majorcina Well, because that Walbro stopped working and it was way smaller than 044. Was actually smaller than OE. I had to use a rubber sleeve that comes with to fit in the basket. If i am not mistaken Bosch 044 is 60mm and OE is only 38mm.
              Recently i did a quick dyno test. Would like to hear some advise. I have to mention that currently i am running on Dmitri's Stage1 with 4bar MAP.
              • LucheS2@20v
                Banned
                • Nov 2015
                • 115
                • Country: Bulgaria
                #52
                This graphic for me isnt cool, something is not ok.
                • wug
                  • Oct 2014
                  • 165
                  • Country: Romania
                  #53
                  AFR shows poor gas on low rpms but that drop of power above 4500rpm might be coming from cams i guess.
                  • wug
                    • Oct 2014
                    • 165
                    • Country: Romania
                    #54
                    Okei, yesterday i did a quick test for engine compression. These are results:
                    Piston 1 -13
                    Piston 2 -12
                    Piston 3 - 13
                    Piston 4 - 14
                    Piston 5 - 13
                    So, my question is now, does the Garrett GT3076R requires a oil restriction or not? As far as i know engine oil pressure is somewhere between 5.5-7 bar and this kind of turbo needs not more than 2.8 bar pressure for a correct lubrication. Please advise.
                    Update:
                    Yes, there is an oil restriction required. Here is what Garrett is saying on their website:
                    "Oil pressure of 40 - 45 psi at maximum engine speed is recommended to prevent damage to the turbocharger's internals. In order to achieve this pressure, a restrictor with a 0.040' orifice will normally suffice, but you should always verify the oil pressure entering the turbo after the restrictor in insure that the components are functioning properly. Recommended oil feed is -3AN or -4AN line or hose/tubing with a similar ID. As always, use an oil filter that meets or exceeds the OEM specifications".
                    • wug
                      • Oct 2014
                      • 165
                      • Country: Romania
                      #55
                      Dyno day ... again, with ABY ecu and RS2 Stage 1 software mods. I used 440cc injectors for this dyno test.
                      • RichLV
                        • Mar 2015
                        • 872
                        • Country: Latvia
                        #56
                        Are you on stock rods?
                        • wug
                          • Oct 2014
                          • 165
                          • Country: Romania
                          #57
                          Yes, engine is completely stock.
                          • wug
                            • Oct 2014
                            • 165
                            • Country: Romania
                            #58
                            Ok, been a while since i updated this topic. Time is always against me. Meanwhile few things happened here. New ecu software from PK Motorsport with 2.3 bar in full boost. Car moves well now. Quick meeting with some local Audi fans. Future plans: summer tires (i know i am a bit late with those ), Boost and AFR gauge, front and rear yellow bushings from Albert. Hopefully can get those in my hands asap. Till then, i am getting ready for a very welcome sea side vacation.
                            • wug
                              • Oct 2014
                              • 165
                              • Country: Romania
                              #59
                              New fresh pics ...
                              • hunker7
                                • Mar 2014
                                • 3487
                                #60
                                That's a stunner. need a spoiler tailgate and that'll finish it off superbly
                                '93 Audi UrS4 Avant
                                '15 Audi A7 quattro 3.0 TDI
