could you have got a bigger fuel pump!! (he says jealously)
building a sportquattro
lol, this is to give a bit more weight on the rear axle
New Pictures
Next week we start bending the rollcage in the SQ
Therefore I welded in the mounting plates in the car and made seat frames for the recaro classics.
I've also got meself a set of FIA approved Schroth 4 point harness belts.
Attached FilesComment
the mockup for the fuel install in the boot.Attached FilesComment
a bit closer. Yes it's still a large pump :mischeif:Attached FilesComment
mustang mountsAttached FilesComment
New master cilinder.
In case you havent noticed the car level again. I've welded a set of dolly wheels underneath to roll the car around more easily.
The upholster guy is also arranged. He's going to the re-upholster the classics in black leather with darg grey/black-ish alcantara in the middle, aswell as cover the headliner and the sills in alcanatara and the door cards and dashboard.
All done with contrasting light grey seams. Oh dearrrr
Someone has got corrosive piss! Have you seen what its done to the seat!!
Nice work Jeffry!
Rob..
87 UR 20v ABY
97 S6 Avant
1967 Ford Mustang,Eleanor,460ci v8Comment
"Exhaust" gasses can be pretty gnarly too you know...
Thos 'stang mounts look as good here as they do on every other Audi forum around. Must say, it felt "wrong" at first but now that I've grown up I kind of like the idea. What is the best source for these babies? They were pretty cheap too, right?
@Jeffer - I thought you wanted her to be naked... No interiour I mean??Comment
The other seat is even more eaten by the piss :S
Change of plans henka. It will have a full interior as I want to use it for "sundays" driving aswell
the stang mounts are from Summit. Indeed pretty cheap. We'll see how they perform.....Comment
:mischeif:
