building a sportquattro
  • Jeffer
    • 2057
    The drysump drive pulley is a gilmer tooth pulley. The pulley on the drysump pump is also a gilmer tooth pulley. So these use a diferent belt type then the timing belt. The Gilmer drive pully will be machined quite substantially to be mounted on the cranckshaft and bolted on the timing belt pulley. This is how the 2 weheels will be connected. The camshaft pully has nothing to do with the drysump system.
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
    • URQguy
      • Sep 2008
      • 245
      Jeff. It looks amazing. I love what you are doing with the drysump. I like the s2forum version of the SQ project. You have been neglecting MG as of late. Good looking IM!
      1981 URQuattro with the TIAL GT35r.
      2007 Infinity g35
      • Jeffer
        • 2057
        Thanks man Hope everyhing works out in the end. I'm often on Motorgeek but i like the S2forum more
        High Octane website
        • Doug_RS2
          • 3847
          #364
          When are you hoping to finish it Jeffry?
          • Jeffer
            • 2057
            as soon as possible Doug. I'm now at a point that I want to drive it, and no more welding!!
            High Octane website
            • G60Rallye
              • Dec 2006
              • 1321
              The amount of welding you have to do on these things is crazy! Its also horrible to weld in some places, seems to have some sort of coating on the metal!
              Hopefully when both our cars are finished we can have a race!
              • Jeffer
                • 2057
                Indeed the welding is a real b*tch on these cars. You really have to clean everything miticulously before you put your welding helmet on. I've pulled my hair on this couple of times. Also make sure there is nu underbody coating nearby. When this is burnt it attracts moist. And the whole lot will rot like hell. I've had to replace a prior good piece of steel. This was rotten through within a year after welding :S
                I'm so happy I'm on the home stretch with welding.
                We sure need to have a mini meet with all the SQ's that are now on this forum.
                High Octane website
                • Jeffer
                  • 2057
                  High Octane website
                  • Jeffer
                    • 2057
                    I welded in a new panel under the front window. The old one had substantial rust on it. That also gave me the perfect oppertunity to weld in the rolcage struts to the firewall. After that I've put on epoxy primer. Looks nice and clean now
                    High Octane website
                    • Acidburn
                      • 13459
                      Looking like quite a bit of progress with it now, soon your be deciding what colour you'd like it to be in
                      • DJ-ROY
                        • Dec 2004
                        • 710
                        Looks clean with that primer on there
                        RS for ‘Rennsport’ - ‘Motorsport’ in German
                        • Jeffer
                          • 2057
                          Its 90% covered in primer. Next stage is to mount to panels and roof permanently.
                          High Octane website
                          • Jeffer
                            • 2057
                            A new update:
                            Roof and rear panels are riveted and glued. Everything is primered and the underbody is coated with 3M.
                            High Octane website
                            • Audi Parts Guru
                              • 1317
                              #374
                              Looking good Jeffer
                              So when do you think you'll have it finished?
                              S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
                              • Jeffer
                                • 2057
                                Thanks Hopefully somewhere this summer. Looking forward to receive it back from the paintshop in a few weeks
                                High Octane website
