ABY to ADU Project
    Originally posted by s2avant
    The dual mass gets ditched because it weighs too much and when it breaks it will set you back £765.73 + VAT!!!
    I made the mistake of fitting a new OE clutch to mine only to have the dual mass goe south after a couple of thousand more miles. Two bills to remove the gearbox is not fun
    Lightweight alloy all the way. You should have had a go revving mine at GTi the difference between ABY dual mass and Alloy is a world apart.
    Ben
    Is that an open offer since your only down the road?
    I wanted to keep the dual mass as i'm told the car is a pig in traffic with a lightweight flywheel and not very nice to drive?
    • s2avant
      • 2426
      It can be a nightmare in traffic but IMO that is more down to the clutch than the flywheel.
      Ben
      • Corey
        Banned
        • Sep 2003
        • 2793
        And look how sexy the ally flywheels look.
        Corey
        01636 822288
          Mmm, way too nice to put in an engine..
            7A FPR is the one Jamo!
            • Jon441cc
              • Dec 2005
              • 2061
              How much weight differance is there between the ABY duel mass and 7A single mass flywheels?
                3B flywheel 10.5kg
                7A flywheel 11kg
                ABY flywheel 14kg
                3B pulley 4.26kg
                7A pulley 4.3kg
                ABY pulley 5kg
                • Corey
                  Banned
                  • Sep 2003
                  • 2793
                  01A ally flywheel 4.5kg
                  Corey
                  01636 822288
                  • Jon441cc
                    • Dec 2005
                    • 2061
                    Cheers jamo ive got a 7A flywheel laying about so might just use that but the 4.5kg O1A alloy flywheels are very tempting.
                    Have you thought of going with water injection to reduce charge temps as i have only heard good things about it ?
                    • Tommy200rs
                      • 285
                      #25
                      >>>>> flywheel 4.5kg
                      It is quite light. You can maybe cope with that if warm engine idle is raised to 1100 to 1300 rpm. I prefer about ~8kg 3B level flywheel. The ligter the better and revs like animal but stop and go traffic is painful.
                      with 4,5kg you can rev up to 9500 if valve springs tolerate the limit.
                      • Ross
                        • Aug 2005
                        • 3399
                        Hehe... glad to see things are finally coming together there Jamo! Feels really great when the part list actually gets smaller (about time!) but you just wait till the bills for fitting it start rolling in
                        I'm getting so ansi to have my car back. I WANT MY S2
                          Heh, and our two projects are linked so too speak :mischeif:
