Audi S2 Coupe Rebuild "Silver Spiken"
  • Eriksson
    • Jul 2004
    • 329
    It had been fun coming over to the UK. 2 of my buddies also drives s2.
    Im going for the green ones, the steering feels a bit sloppy. everything is replaced.
    Hope new ones sorts the problem.
    Also im looking for a whiteline Rarb.
    One Question. what setting should i use on my konis ?
    i will adjust them when i change the top mounts.
    now i have softest rear and one turn on the front.
    I would really need some advice for this.
    will fix batteries for my camera tomorrow, if i have the time i will post a movie.
    Cheers Pelle
    Audi S2 Coupe - 92
    Koni + H&R. PowerFlex bushes. 3" Exhaust
    RS2 IC. RS2 TURBO. RS2 EX MAINFOLD
    Best ET 2006 13.8 @ 157 Km/h (Stock turbo and EX mainfold)
    Best ET 2007 12.78 402m, 0-62mph: 4.2 sec, Speed: 175 km/h (GTEC)(1.1bar)
    Best ET 2007 201m 8.15@140km/h
    Best ET 2008 402m 12.34@177km/h
    My Project
    http://www.s2forum.com/forum/showthread.php?t=16997
      From memory I did two turns front 2.5 rear
      • Eriksson
        • Jul 2004
        • 329
        so i should have a stiffer setting on the rear ?
        Audi S2 Coupe - 92
        My Project
        • Corey
          Banned
          • Sep 2003
          • 2793
          Koni give you 720 degrees of adjustment, the fronts want 50% (1 turn from soft) the rears 75% (1.5 turns from soft). Always makes sure that you return the adjustment back to it's softest setting before adjusting (not applicable to top adjustables)
          Corey
          01636 822288
          • Eriksson
            • Jul 2004
            • 329
            Okey. so the rear shal be harder than the front.
            Good thig to know, i will remove the top mouts next week.
            Audi S2 Coupe - 92
            My Project
            • prosty
              • Jun 2005
              • 1114
              You need more boost / power
              BR / The fastest in the garage
              2004 9-5 aero
              2009 Subaru Legacy Diesel
              1994 Toyota Supra Eurospec 6-spd LHD
              3-4 Audis in parts
              • Eriksson
                • Jul 2004
                • 329
                Yes i know
                Can post another of your pix of your car, the quattro system is good. but you were really stuck here.
                Custom made rs2 ic mount
                The Great MarkH ic mod
                First test drive with the 17" + Potenza RE050A and 8mm H&R Spacers
                Propshaft overhaul
                New BMW Central Bearing
                Pita to get of
                Audi S2 Coupe - 92
                My Project
                • Eriksson
                  • Jul 2004
                  • 329
                  New Central Bearing mounted
                  Repainting the side skirts
                  The white is body filler, as you can se on prostys car we have a rough winter up north
                  Audi S2 Coupe - 92
                  My Project
                  • prosty
                    • Jun 2005
                    • 1114
                    Yeah some ppl don't have the guts to floor it when going on the track
                    2004 9-5 aero
                    3-4 Audis in parts
                    • Eriksson
                      • Jul 2004
                      • 329
                      How do i edit my previous post.
                      Want to fix my pictures.
                      Here is some new when i changed my top mounts and brake fluid.
                      H&R Lowering spring
                      New Top mounts
                      My manual WGFV
                      Empty
                      Audi S2 Coupe - 92
                      My Project
                      • s2dude
                        • Nov 2005
                        • 1631
                        Hey!
                        Unfortunately posts cannot be edited after 24 hours ....unless maybe a moderator can do it?)..
                        As for the vague steering you describe...
                        Have you tried this......I have to do this also and have an identical problem. It could well be your fix
                        Keep us posted
                        • Eriksson
                          • Jul 2004
                          • 329
                          Okey.
                          I have tried to adjusted the bolt but it was a PITA to get loose.
                          Dont know what the sound should be like and how mutch to unscrew the bolt before adjusting it.
                          Audi S2 Coupe - 92
                          My Project
                            why arent you using a WGFV?
                            • Eriksson
                              • Jul 2004
                              • 329
                              Because my car is not mapped or chipped for my rs2 turbo, ic, 3" exhaust.
                              It's an turbocenter 270 hp chip boost around 1.4bar
                              If i use the WGFV the rs2 turbo will flow a lot more air than the Stock turbo.
                              Also they say that you get quicker spool up if you use an mechanical boost control.
                              Im gooing for 1bar WG spring and run about 1.1 bar until i find a EX mainfold and larger injectors.
                              And get it mapped and run 1.5 bar
                              Now im using stock WG spring 0.4 bar, but i have tried a 0.75bar wg spring and it was quite a diffrance, faster spool up and the boost didn't drop at higer RPMs
                              Audi S2 Coupe - 92
                              My Project
                                I can understand the rational, when you have it mapped properly definetly go back to using the WGFV since the tuner can then have proper control of the boost over the whole rev range, how is it running now?
