Now its running like crap probbably some boost leak.
It ran wery well but so low boost 0.9bar.
will look at it tonight. will post a video later when it runs well.
Audi S2 Coupe - 92
Koni + H&R. PowerFlex bushes. 3" Exhaust
RS2 IC. RS2 TURBO. RS2 EX MAINFOLD
Best ET 2006 13.8 @ 157 Km/h (Stock turbo and EX mainfold)
Best ET 2007 12.78 402m, 0-62mph: 4.2 sec, Speed: 175 km/h (GTEC)(1.1bar)
Best ET 2007 201m 8.15@140km/h
Best ET 2008 402m 12.34@177km/h
My Project http://www.s2forum.com/forum/showthread.php?t=16997
Now the car runs fine again.
but still dropping some boost at higer revs, don't know why, mayby the std WG spring.
Will hopefully get a stiffer tomorrow.
pic for you all
Audi S2 Coupe - 92
Today my new 1bar wg spring arrived.
Will fit it tonight and hopfully everything will work fine.
Audi S2 Coupe - 92
My AFR value where as low as 9.89 at WOT boost about 1.1-1.2 bar
What could be the problem ?
mayby i just need it to be mapped right.
Setup:
K24 7200
3" Exhaust
rs2 IC
Stock inkectors
Stock EX mainfold
270hp chip (for stock car)
It feels like its just no power @ wot.
Audi S2 Coupe - 92
Im going to make some new tranny mounts.
stiffer ones. will post pictures as i make them.
I have changed engine mounts and make a snub mounts out of a SPQ mount.
Started whith 2 Std Hockey Pucks (made in Czech republic)
Some cutting done
Cutted to the right size.
Tomorrow i will make a plate the shape of the original mounts shape.
But only whith a smaller hole in the middle.
Cheers Pelle
Audi S2 Coupe - 92
New Superflex Subframe bushes arrived last week.
Rs2 EX mainfold is installed
Delphi 550cc injectors are on its way frome the states.
Whaiting on some special Camskäfts, called Sture (EX) and Sven (IN).
And i think im the only one whos going to try to use A modified Stock ABY Airbox for my setup.
rs2 IC
rs2 EX Mainfold
rs2 Turbod
3" Exhaust
3,5" MAF (or bigger)
Audi S2 Coupe - 92
Brand NEW Delphi 550cc injectors have arrived from the states today.
The Boys!
Audi S2 Coupe - 92
where have you buy Superflex Subframe bushes are they the same as the bushes in the rear (subframe) i hav changed the all bushes to powerflex but they dont have them to the back subframe???
powerflex do the bushes for cast and pressed wishbones. Where as superflex only do one type, I cant remember if it is for cast of pressed wishbones though
Jag köpte dem hos KG trimning [lnk]http://www.kgtrimning.com/[/lnk]
Det ska tydligen vara samma till båda bryggorna. annars är det bara att anpassa metallstaven. köpte 2 st kit. (fram o bak )
MVH Pelle
Audi S2 Coupe - 92
The modifikation of the original ABY airbox has began.
And some other things this weekend.
Orginal ABY Airbox
My friends RS2 Airbox
My new Modified intake side of the box over 4 inches.
Also i changed my reart disks and pads.
it was about time....
The new ones..
BIG Congrats to my homie Prosty, Addi is roling again!
And to my friends Ante and Tony who helps on the way.
Cheers Pelle
Audi S2 Coupe - 92
This weekend i have dissembled the rear part of the car
and changed my Rear subframe bushes for the new Superflex ones (NICE).
And the right handbrake cable. Also Mounted my newly modded Airbox.
Next weekend i will brake apart the front subframe, changing to Superflex (NICE)
i will post pics later tonight.
Now i have:
Powerflex Front Whisbone bushes
Powerflex Rear Whisbone bushes
New engine mounts
New gearbox mounts
New prop bearing
Special Diff bushes (homemade)
Superflex rear subframe bushes
Superflex front subframe bushes (soon)
New Top mounts
Yellow Konis x4
H&R Loweing Springs
Prosty's Old front discs
Im going to order stiffer gearbox and diff mounts from 034 motorsport,
But First i will order a Whiteline RARB from Corey.
Does some one know what front disk to use for Porshe 968 rear callipers ?
Cause the originals is a bit to big... when mounted in the original possition on the hub.
Cheers Pelle
Audi S2 Coupe - 92
