Building a S2 mk2 golf
This is a sticky topic.
Ok dont rub it in
The welds did hold but the backfire was enought to bend a thick throttle plate
also pushed the fuel rail into the bonnet and bent the both
Forgot to add, i put it on the weigh bridge at work and it came in at 1140kg with about 15l of petrol
The ONLY S2 Golf!
10.42@138mph
https://m.youtube.com/watch?v=0wnkkOfFpXgComment
Motoscope, they have a v good 4 wheel drive rolling road
The ONLY S2 Golf!
10.42@138mph
6mm back plate, everything else 2.5mm but the design was flawed before i started it needed to be conical.The ONLY S2 Golf!
10.42@138mph
Its not pretty. no 3 piston decided to detonate
Im going to pick up a block from sal asap so i should be back up and running soon.
I think there was a short in the +12v to no1 coil making it fail under load, causing the lambda's to read rich when the others were dangerously lean.
Apparently its not uncommon for a coilpack failure to destroy an engine.The ONLY S2 Golf!
10.42@138mph
gutted for you looks well ****ed i take it the block is a wright off thennever set your expectations to high that way you are never disapointedComment
