Building a S2 mk2 golf
This is a sticky topic.
  • Flat on my back
    • Jan 2007
    • 2449
    Its called 'phut testing'. Goes like this:-
    Apply power, wait for 'phut' sound, look for smoke and then listen for the 'bang'.
    If none of the above happens design is satisfactory, if some of the above happens design needs modifying?
    Carlos.
    • Avtor
      • Oct 2007
      • 27
      • Country: Russian Federation
      #152
      R5
      • Sc0rian
        • Nov 2007
        • 1
        truly amazing mate, total respect..
        you got some skills.. cant wait to see this going up the strip
        • gnutz2
          • Aug 2006
          • 928
          Got some more parts off ebay including 6x 650cc low imp injector i`ll be running five of these outboard and the standard ones in the stock location.
          Also recived all my fuel fittings from pace and fabricated the fuel rails and the outboard injector holders. This was a pain in the *** because i had to make all the injector bushes with a high quality finnish (not easy on lathe probably twice my age)
          I kept the fuel rails big because im running all the injectors in batch mode so they will all fire at once, i`m very optomistic that this injector arrangement will make quite a bit more power than standard, but i`ll still have the benefit of running the original injectors.
          The ONLY S2 Golf!
          10.42@138mph
          • Acidburn
            • 13459
            As you've been told your work is amazing, be interesting to see how this works out when you start mapping.
            • gnutz2
              • Aug 2006
              • 928
              It will be a pain in the backside to map, the extra injectors can either be switched on with load or rpm but obviosly there will be a big drop in the map at this point which will be a critical point.
              The ONLY S2 Golf!
              10.42@138mph
              • Wolfgang
                • Mar 2006
                • 250
                absolute insane project. Big respect!
                keep on going!
                can´t wait to see the golf flying
                S2 Coupe ABY
                S2 Sedan
                S6 20V Avant
                www.audis2.de
                • Neutech
                  • Dec 2007
                  • 121
                  • Home: Ireland Current: Northern Ireland
                  #158
                  Wooowwwww
                  Have nearly finished a mini Mk2 project.........only a poxy 2.0 16v Motor in it though
                  Excellent Engineering
                  I'll be keeping an eye on this thread
                  WTD - B3 coupe Quattro
                  • blurtmagnet
                    • Sep 2007
                    • 136
                    just a note on the tig welding, rather than fork out for a new torch you can buy smaller ceramics and longer tungsten carbides for the small spaces
                    just a thourght
                    • gnutz2
                      • Aug 2006
                      • 928
                      Pics, pics, pics I love it
                      Cannot wait to drive this thing, it`s doing my head in
                      The ONLY S2 Golf!
                      10.42@138mph
                      • topsparky
                        • Oct 2005
                        • 2014
                        that looks gr8 gaz
                        what are you doing with the IM
                        are you shortening the runners
                        when are you going to
                        get her running??
                        1. SHORT SHIFT KIT
                        2. PORSCHE CAYENNE CALIPERS
                        3. H & R SPRINGS
                        4. BILSTEIN SHOXS
                        5. NEW BUSHES AND HP2 STRUTS
                        6. UPRATED HIGH OUTPUT COIL PACK
                        7. ,3" turbo back s/s/ exhaust
                        8. fmic fitted
                        • gnutz2
                          • Aug 2006
                          • 928
                          Runners are staying that length there`s gonna be a hole or a hump in the bonnet, unless i cut and weld them at an angle
                          Should be on the road for april!
                          The ONLY S2 Golf!
                          10.42@138mph
                          • topsparky
                            • Oct 2005
                            • 2014
                            can't wait to see this car gaz
                            i knew when me and bry dropped those calipers
                            off to you it was going to be something special
                            1. SHORT SHIFT KIT
                            3. H & R SPRINGS
                            4. BILSTEIN SHOXS
                            8. fmic fitted
                            • gnutz2
                              • Aug 2006
                              • 928
                              Did`nt realise it was you thanks for that.
                              Topsparky, it`s Baz not Gaz
                              The ONLY S2 Golf!
                              10.42@138mph
                              • topsparky
                                • Oct 2005
                                • 2014
                                sorry mate
                                1. SHORT SHIFT KIT
                                3. H & R SPRINGS
                                4. BILSTEIN SHOXS
                                8. fmic fitted
