Used my mums camera to get some better pic`s
Building a S2 mk2 golf
This is a sticky topic.
The ONLY S2 Golf!
10.42@138mph
Yep, great project, with a really interesting set of pictures and write up....
Really enjoying following this one......!
Chris
is simply awesome you are GOD
i never saw nothing similar....
pd:here is spain i meet a forum friend with an ur-quattro with a hibrid engine made it of of him. with a pieces od aby,3b,rs2 and s4 parts. he loves this clasiccs audi cars and his nick is SPORTQUATTROLOVE you will be must his friend
bye masterRED Mitsubishi Lancer Evolution VI TME nº 16 of 250
Got the ecu, DTA s100 and also on the way is a 5 bar map sensor, water temp sensor, air temp sensor, crank shaft sensor, Trottle pos sensor and need to get a good quality wide band lambda, loom kit from this company http://trigger-wheels.com/store/ and i can start making the engine loom. thankfully no need for a cam sensor thanks to waste spark, and Audi CQ.
I started to finnish off the plenum now i know where everything is going in the engine bay, the kit i got from the US makes the runners come right out of the bonnet so i might cut and weld them to bend them down a little.
I won 6 x 670cc injectors off ebay which im going to mount on the back of the plenum, i`ll stage them in to take over from the standard injectors.
I was thinking about buying a fuel tank but i have no money left so i had to make one, funny thing is the fuel cap cost more than the aluminiun did to make it. I ported and polished the cylinder head too which you can also see in the picture.
I also orderd a davies craig 80 l/m water pump (for the charge cooler) and a 320 l/h fuel pump by Walbro. So i`ll be plumbing up the fuel lines soon and hopefully getting her fired up ready for 08 summer.The ONLY S2 Golf!
10.42@138mph
Sweet welds specially the 'tigging', whats your set up, how many years you been practicing?Carlos.
I`ve been tig welding about 7 years now and it still does my head in (sometimes i get it right) i`ve allways used the tig at work, but last year i bought my own for this project.
http://cgi.ebay.co.uk/240V-AC-DC-200...QQcmdZViewItem
Unbelivably cheap very good quality, arrived in a couple of daysfrom china too.The ONLY S2 Golf!
10.42@138mph
Tig welders usually are more than that. you can expect to pay £1500 for a AC/DC 200A.
It is very hard to get used to and it does improve with practice. but the gas, filler rods and consumeables are quite expensive especially if you purge your joints.
The best advice i could give ror aluminium is keep it clean, clean and even more clean
If you cut the alloy with a angle grinder this contaminates the joint so you need to clean up the joint with a file then a wire brush and i all ways wipe the joints with some solvent to remove any greasy residue from my handsThe ONLY S2 Golf!
10.42@138mph
Originally posted by denniselbows View Postwell i thought tig welders were loads more than that. had always thought about getting a tig welder my self. is it hard to get used to? or is it just the same as other welding the more you do the easyer it gets.
www.mig-welding.co.ukCarlos.
I have said this in another project, but will say it again..
Good looking welds on that plenum. Good_looking_ design, let's just keep our fingers crossed, that it won't explode in first testdrives.
How thick plate did You use? I'd say You need at least 4mm plate for that design...Everything less than 2 bar is considered to be naturally aspirated
Originally posted by repo View PostI have said this in another project, but will say it again..
It`s all development which is what i love about building carsThe ONLY S2 Golf!
10.42@138mph
Originally posted by gnutz2 View PostI`ve been tig welding about 7 years now and it still does my head in (sometimes i get it right) i`ve allways used the tig at work, but last year i bought my own for this project.
Great piece of kit!
Have you had the gas solonoid stick in the on position? gas pouring out long after it should be.
Changed my tourch to a Binzel with a valve on the handle to stop the gas when it does its "trick".
I paid a bit more than that, made a new fuel tank for a Aston V8 first job, Tig paid for and some in its first job!Rob..
87 UR 20v ABY
97 S6 Avant
