My Ocianic Blue Ur restoration
  • #46
    Originally posted by steve briance View Post
    Happy days. Thats a relief not having to perform surgery!
    I'm sure your plan for the underside includes the full treatment, back to metal, treat rust then apply epoxy/underbody stuff?
    Don't forget to have a good root round inside the body where the captive subframe nut is...mine was literally full of dried mud. Heaven know's how this had affected the hidden metal but - a good poke out with a bent wire released a small pile of mud dust, blast with hose, dry and then plenty of dinitrol penetrating cavity wax pumped in there should have done the trick.
    Yes, good plan. I don't know why they put a small drain hole there
    Would it not be better to have sealed it all up?
    • #47
      There is a drain hole as it was that and the bolt hole where my wire poked through but it drains right into the path of the subframe mount! I'd post a video of how much fell out of mine but don't know how to on this forum.
      • #48
        congratulations got it out I forgot to mention I may have a good pair of engine mounts available
        • #49
          Thanks Joss. I will send you a PM
          • #50
            Progress is slow due to life getting in the way. However, I had the rear subframe blasted and it wasn’t as bad as I thought. Just one small hole which can be welded. It’s off for galvanising shortly.
            • #51
              Galvanising is THE best way forward - deals with the inside where powder coat doesn't.
              Had mine done this year and then I painted ​​​​​​in epoxy. Can forget about that job now for the remaining life of the car / petrol supplies / me ​​​​​
              This gallery has 1 photos.
              • #52
                Its all in the detail looking good Dave why did you decide on galvanising instead of powder coating?
                • #53
                  As Steve says. It's the best way to protect long term.
                  • #54
                    Slowly working my way through the engine bay, marking up as I remove.
                    The tank is out. It is very clean with no sign of rust inside, just the outlet pipes a little rusty.
                    And I found these on gumtree. Boxster calipers for the front.
                    • #55
                      hi dave have you found a supplier who fabricates the adaptors for the callipers?
                      • #56
                        Try these people, they have a wealth of knowledge
                        • #57
                          Yes, Rob from Quattro bits but he is currently out of stock.
                          • #58
                            Try these people.
                            Cheers Steve
                            • #59
                              Got a couple of hours in today.
                              Getting there slowly.
                              • #60
                                I can machine whatever you need Joss
