I purchased a 83 Ur Quattro that has been sitting for years in a disarray. Previous owner purchased a AAN 20v out of a 93 S4. Car has never gotten far enough along to start or drive, so now I am going to strip everything down to bare bones and start from zero.
83 Ur Quattro 20v build
Engine has been pulled and completely torn down to be cleaned. Jeff with Four Rings Performance will be building the engine. Looking for 450 hp on pump 93 and mid 600’s on E85
- 2 likes
Had a “Gentleman's” cage built out of 1 3/4” .120 wall chromoly. The plan for the car is to be a daily driver with full interior, AC etc. so a full race cage would not work. This cage helps stiffen up the chassis and ties everything together plus adds a bit of safety. Front strut mount also built
- 2 likes
Actually, there has been some rust issues that have been addressed. The drivers rear quarter has been replaced and both front rockers. The work was done very well. I just patched a rust spot in the engine compartment and have the rear passenger lower back wheel well to tackle. But for the most part, the car is in pretty good shape. Eventually the car will get blasted before paint and anything else will be addressed.
- 1 like
I cut the front cross support, so the motor and trans can come out the top instead of dropping the sub frame. I was given a front clip, so I cut out a left and right section and made a center flange. I welded everything in along with nuts on the back side and threaded inserts. Very easy removeal and install.
- 3 likes
Have removed the fuel lines, parking brake, rear diff, both front and rear sub frames along with KW shocks. Next I will get engine bay and underside cleaned and address any rust and then recoat underside.
- 1 like
Good to see another sucker for flared box arches! Great project, looking forward to following this thread. Lots of photos, even of “boring” stuff, please.1996 S2 ABY Coupe silver
2003 S3 8L dolphin grey
2014 RS4 B8 prism silver
- 1 like
Varia, you are 100% correct. I will not be using the header, turbo or intercooler. Previous owner paid to have header made to fit his needs and the intercooler is too small, but nicely made. I am using another SS custom header with larger tubing and aluminum intake I bought along with FYY o1E 6 speed trans / matching diff and more stuff. Jeff will figure out the turbo I need
Attached Files- 71864601322__A2E383E3-E883-47AD-9AD9-3E0BE0561197.jpeg (4.09 MB, 152 views)
- 71864642418__707C2126-64F8-4BD6-9886-F386ECA54F75.jpeg (3.09 MB, 151 views)
- 71864643492__48497FB3-CC1A-454B-A1C5-569BEFC46983.jpeg (2.95 MB, 154 views)
- 1 like
I acquired a rare Ron Davis radiator and mounted a Spal Fan and a AC condenser. Yes, I want AC/Heat and all the nice comforts in my car. The AAN 20v engine is wider than the 10v so the radiator does not fit, So I modified the AC mount and the chassis to fit. The Audi AC compressor is a rear connection, which will hit the radiator, so I will mount a 507 side port used on mid 80's Porsche 911's.
Sorry for pictures out of sequence....not sure how to fixAttached Files- 37F6A0A8-DBEB-41AF-A577-AACC72D536BD_1_105_c.jpeg (280.0 KB, 159 views)
- 1 like
Varia.....its a 16" fan with 2024 cfm, I think I am fine for my application, used same fan on Porsche 928 LS3 Super charged making 650 at the wheels and a few other high hp motors, its not my first rodeo, but truly appreciate your incite and hope I am not wrong on this build
